Page 1 of 6 123456 LastLast
Results 1 to 10 of 58
Thread: Fiberglassed Gauge Pod in Bezel: FIXED *pics*
    Aug 2006
    Alright I screwed this up the first time, now I fixed all the holes I drilled in my dash when I shouldnt have. Now I have my "PVC pipe gauge pod" glued in place in my vent.
    Now how do you suggest I get started on filling in the vent around the gauge pod hole?
    I attached pictures.
    Thanks. - Jeff
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    use pantyhose and hot glue. stretch the material over the surface to the outer edges of the vent. (i assume you've already secured the PVC). paint it with resin and let it cure. Don't put resin where you plan for the gauge to be or you'll make more work for yourself. Just enough to make sure it sticks to the lip of the PVC as well as the edges of the vent. When the resin cures, start applying your chop mat, dynaglass, dynatron, duramix whatever to the INSIDE of that delicate pantyhose shell you have. When your reinforcements are dry, you won't have NEARLY as much work to do on the outside, plus your shape stays pristine for the most part, and after trimming off the glue, you'll only have minor feathering to do with your favorite filler.
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    what go hybrid said
    or u can fill it with foam.., or if you have any plastic strips you can put over and epoxy into place.., whatever you have really that you think will look best
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i dunno. this just seems like it's prone to cracking. make sure you reinforce the area where the glass meets the abs. one's going to flex, one wont...i think you may get stress cracks.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jun 2006
    Denver, CO
    or you could drill holes all over the dash and just 'glass the whole thing...
    just messin wit ya
    Low Bitrate GFridrich3's Avatar
    Sep 2006
    Chicago Suburbs
    Just a quick question, but with the room you have on the vent, and from the sounds of your post, your going to be blocking off airflow from that vent? If you are doing that, why didnt you just put a 2nd pvc gauge ring in for a dual gauge setup? There would have been a lot less glassing to be done since you would only have a few small areas to cover instead of 2 very large ones. Besides, when your ready to put another gauge in, you dont have to start all over again...
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    not to be an asshat, i think you should have made a ring out of pressboard, MDF, resin adheres to it better than a fiberglass. or even the whole this,
    cut a rectanlg eof MDF, doesn;t have to be thing, so it exactly fiut the vent, attach mdf to piece to the dash, then cut out of hole in mdf for the gauge,
    that way it would not flex, then you just reinforce with glass , some glazing putty, and you all set
    other
    R. T. F. M
    Nov 2005
    Chicago
    the colored part is mdf, becuase it eould be stirty filling, it wound actually reinforce your set up, the you just need to add fiberglass, and sand it for a shape, then bondo or grazing putty coat, sand paint, and you are set
    and of couse attach MDF with epoxy to your dash
    Yev
    R. T. F. M
    Jun 2006
    Denver, CO
    just show us all how to curve MDF and we'll be a happy lot.
    Nov 2005
    Chicago
    i said the put glass in the mdf, that would it would be a solid base for fiberglass
    Yev
    R. T. F. M
  1. Fiberglassing Gauge Pod in Bezel *pics*
    By jmilin5931 in forum Fabrication
    Last Post: 10-04-2006, 09:04 AM
  2. F/S: Voltmeter Gauge with Pod
    By ricerZ in forum Classified Archive
    Last Post: 07-05-2006, 10:35 AM
  3. anyone put a lcd in a gauge pod?
    By crash893 in forum LCD/Display
    Last Post: 11-18-2004, 10:10 PM
  4. Mounting motherboard in WRX gauge pod housing..
    By Giuliano in forum General Hardware Discussion
    Last Post: 07-19-2004, 10:01 AM
  5. WRX owners. Clock or Boost Pod Gauge area. Center channel Speaker.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 04-02-2004, 05:37 PM
