Results 11 to 20 of 27
Thread: Modifying a Plastic Bezel. Epoxy, Fiber, Bodyfiller+Resin?
  1. #11
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    Quote Originally Posted by Yevmeister View Post
    well by doing that the difficulty is handred times tougher
    but here is the solution, you can buy a empty 8 inch dimater liilipiut monitor housing, i am sure that lcd panel is the same, so it will scren in in hinges no problem
    $15.00 @ http://digitalww.com/lilliput_housing_8.htm
    the only other simple way i see you accomplishing is custom Plexiglass cutout, where you can implant lcd hingles, and infrared
    Yev
    I saw that bezel and considered it but i'd need exact measurements to make sure it fits the screen well.
    I dont see why i would need a custom plexiglass cutout. I' plan on using the back of the lcd housing, a piece of plastic, some screws and some tape to hold it into the bezel.
  2. #12
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    screen will fit no matter what cause lcd boards are standardized size, check out lcd display forums for 8 inch lilloput, and comapre dimensions with what you have
    tape, even hot glue will not work after driving for awhile with so many vibrations puddle, eventually it will fly off, you will need a window cutout inside the faceplate you can utilize touch screen
    Yev
    R. T. F. M
  3. #13
    Sep 2006
    Georgia
    Yev
    dimensions dont match
    I have
    width 7 7/8"
    height 6"
    For my screens active area
  4. #14
    Nov 2005
    Chicago
    oh well i am sorry to hear that, all i can do is wish you a goodluck,
    please don't hesitate to pm anytime you have a question
    Yev
    R. T. F. M
  5. #15
    Jul 2001
    your only viable option then is to make a mold out of the bezel that you currently have. Id also try contacting the company directly to see if they will sell you a seperate bezel, cause the work involved any other way is just too time consuming for nothing gained
  6. #16
    Sep 2006
    Georgia
    Quote Originally Posted by Ces///M3 View Post
    already contacted them
    looking into a mold. Dont know hjow to go about it
  7. #17
    Nov 2005
    Chicago
    go to farwest plastics materials (http://www.farwestmaterials.com) buy a trial kit of OOMOO 25 1 quart i belive is around $20.00, then get a fast drying resin (smoothcast 300) about 25 for a quart as well.
    make a cardboard little bigger size than bezel, pour OOMOO, wait few hours, one it harderns it will become like a rubber mold, then poor resin, and here is your duplicate bezel
    check out my little tutorial here
    http://forum.axishistory.com/viewtop...ight=make+mold
    I have some of smoothcast 300 @ home few gallons, i can get it 4 oz just enough for 2 trial bezels, if you are intrested please pm, i don't have OOMOO though
    Yev
    R. T. F. M
  8. #18
    Sep 2006
    Georgia
    Welp I got bored and epoxied more in and cut a hole
    The hole is almost actually perfect. But I think i'll be mounting a bezel into it anyways.
    Still have one more tube of expoxy. Don't know if i should bother filling more in with epoxy or using bondo at this point. If I do merge a screen bezel into it I'll end up having to make the hole bigger.
  9. #19
    Sep 2006
    Georgia
    Ouch, just found out that a replacement enclousure from Dynamix cost $50.
    I'll prob hack up my bezel
  10. #20
    Sep 2006
    Georgia
    gone
  1. Black Fine Textured Plastic for Bezel
    By F350 in forum Fabrication
    Last Post: 08-05-2011, 01:10 PM
  2. Fiberglassing Gauge Pod in Bezel *pics*
    By jmilin5931 in forum Fabrication
    Last Post: 10-04-2006, 08:04 AM
  3. ****Celica Carbon Fiber Car Computer Finished****
    By hombredelassrta in forum Show off your project
    Last Post: 09-02-2006, 02:22 PM
  4. Resin Resistant Plastic Bag?
    By CBDZ in forum Fabrication
    Last Post: 06-09-2006, 02:30 PM
  5. Replies: 1
    Last Post: 10-18-2003, 12:29 AM
