Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Where to find track sliding panels
  1. #11
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you could also use a router and some mdf to make a track
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #12
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Quote Originally Posted by scott_fx View Post
    Then you could follow curves. I refinished an old cabinet for my grandma that had these type of doors. Looked pretty simple to build.
    Failure is not an option....
    It's installed by default on every version of Windows.
  3. #13
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    quick and easy solution, than just fabricate, and reinforce with some resin, and you are set
    Yev
    R. T. F. M
  4. #14
    Jul 2001
    MDF is strong, why would you need to reinforce it?
  5. #15
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Tambour (or rather finding them) sucks.
    I started to make my own. I later abandoned it as I'd have to cut away too much of the dash inside.
    I just used a sheet of 3/16 abs, cut it to size of the overall door, then cut it into slats, the tricky part was cutting out the tabs.
    Then I glued it with spray adhesive to heavy canvas. It's quite strong, but doing the tabs by hand is a PITA.
    I was going to have the slats made by a company that did CAD production. I believe it would have been under $40 USD to have them laser cut out of 1/4 abs.
    Some pics of what I did, keep in mind, this was intended as a proof of concept.
  6. #16
    Apr 2005
    Boston, MA
    One other thought, google for the Doom 3 case mod. The metal blast door is awesome and pretty much what you want. He doesn't give enought details though.
  7. #17
    Nov 2005
    Chicago
    not bad, i have ace harware 5 blocks away from my work, i will go there and check out what i can do for strips, thechnically you can even get away with wood pieces, but abs would be perfect contender
    Yev
    R. T. F. M
  8. #18
    Dec 2004
    Los Angeles Ca
    just looks like you needed to make those slats slimmer and maybe a bevel on the edges. i bet you could have made it retract along an upside down 'u' track w/o having to cut too much
    M10k
    My Car Pc Install
    My Boat Pc worklog
  9. #19
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Yevmeister View Post
    Yev
    yev, check out www.mcmaster.com you can buy thin strips of acrylic (probably abs as well) on the cheap. that would eliminate a lot of cutting on your part. another option is to get a sheet of material (maybe even carbon fiber) and send it to a laser cutting service and have them make clean uniform cuts that follow the profile that you need (if you wanted a 'notch' in the ends)
    M10k
    My Car Pc Install
    My Boat Pc worklog
  10. #20
    Apr 2005
    Boston, MA
    I definitely needed cleaner edges, but even as, worked ok. The problem was having to cut out an important peice that provides a lot of strength to the dash (it's a sparse area, that's prone to cracking in general on my car) to fit it over the top of the lcd.
    I could have done it from the side, but decided flip out doors would be better (which I still haven't done )
  1. Bug in Track time?
    By chuckie_mn in forum Media Engine
    Last Post: 02-02-2005, 09:22 PM
  2. Replies: 1
    Last Post: 12-13-2004, 11:55 PM
  3. TRACK NUMBERS_can't get the track numbers to display properly
    By fly_dutchie in forum FP Bug Reports
    Last Post: 11-06-2004, 01:44 AM
  4. mp3 names in Mediacar to include track nr?
    By fly_dutchie in forum MediaCar
    Last Post: 07-15-2004, 12:53 AM
  5. Random LCD idea - track movement?
    By Rover_Eli in forum LCD/Display
    Last Post: 01-22-2004, 11:34 PM
