Results 21 to 30 of 31
Thread: Where to find track sliding panels
  1. #21
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    look what i got
    this is a wall base trim, with adhesive part, i believe it's flexible rubber with ABS compound
    i think i will be able to work with that
    Yev
    R. T. F. M
  2. #22
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i remember those, industrial 'baseboard' i used to sell that stuff when i worked at the hardware store when i was in HighSchool...ugh...too long ago
    some problems i see with that:
    hard to 'tool'
    high friction
    flexible across x-axis (wouldn't you want something that was stiff?)
    how are you going to paint it?
    if you can get it to work; great, more power to you. just wanted to alert you to some hurdles you may have before you invest time iinto that.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #23
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by scott_fx View Post
    hard to 'tool'
    high friction
    Ditto. Especially on the flex.
    Home Depot must sell wood slats right?
  4. #24
    Nov 2005
    Chicago
    thue, but little flex wound hurt as much if you just want covering
    it doesn't flex as bad, it just because of the size, if i cut them in 7 inch stripes, and attach it to the jeans material i should be okay
    Yev
    R. T. F. M
  5. #25
    Nov 2005
    Chicago
    i gove up, i need to find better solution so i am going to the hardware store tomorrow, i have about 1/3 inch space in between the bezel , and the monitor, so i am also look for ideas to make a track
    Yev
    R. T. F. M
  6. #26
    Dec 2004
    Los Angeles Ca
    id suggest going to you local hobby store instead of the hardware store
    M10k
    My Car Pc Install
    My Boat Pc worklog
  7. #27
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    I would pc-7/weld some 1/2" x 7"(or whatever) strips of ABS or aluminum to small hinges or just thin wire cable on each end... the track wouldnt be hard at all...
    in the metal section of home depot, get like 4 feet of angle aluminum. snipe out the area where an angle is desire... make duplicates for each side and tack/rivet them together, leaving enough space between for the ABS/Alum. door
  8. #28
    Nov 2005
    Chicago
    my search is over i went to the local hobby shop, asked the guy for abs plastic strips, so he took me to the small section, i picked up few abs strips for tracks, and a styrene flexible piece of plastic for slider, all cost me $15.00 considering hobby stores are expensive
    Yev
    R. T. F. M
  9. #29
    Mar 2005
    Maryland
    that'll work too... except i would recommend metal tracks...
  10. #30
    Nov 2005
    Chicago
    i i went ith ABS because it easier to bond it to ABS faceplate
    Yev
    R. T. F. M
  1. Bug in Track time?
    By chuckie_mn in forum Media Engine
    Last Post: 02-02-2005, 09:22 PM
  2. Replies: 1
    Last Post: 12-13-2004, 11:55 PM
  3. TRACK NUMBERS_can't get the track numbers to display properly
    By fly_dutchie in forum FP Bug Reports
    Last Post: 11-06-2004, 01:44 AM
  4. mp3 names in Mediacar to include track nr?
    By fly_dutchie in forum MediaCar
    Last Post: 07-15-2004, 12:53 AM
  5. Random LCD idea - track movement?
    By Rover_Eli in forum LCD/Display
    Last Post: 01-22-2004, 11:34 PM
