Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Flexible, raisable, swing-arm thingy?
  1. #11
    Jul 2004
    Irvine, Cal
    Quote Originally Posted by seanz0rz View Post
    yea, bounces more than a lowrider tho...
    im going to build a fixed mount out of square tube steel (1/2 inch, 1/16 wall maybe?)
    You mean the goose neck swings back and forth? Mine is real stiff, doesn't move unless you really put some force into it
  2. #12
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by DJiK View Post
    If I had your car, I would so mold the screen where the conventional in-dash-gauges go. Right behind the steering wheel.
    i would do something similar but move the oem screen to the area behind the steering wheel and then put your touchscreen where the oem is.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #13
    Newbie Greasyrider's Avatar
    Nov 2006
    tennessee
    Quote Originally Posted by HitmanZ View Post
    I need one of these, but don't want the sway. Do you remember the guys username on ebay, I searched and didn't find any.
    I almost bought the Parts express one, but i'm putting a 10.2 Xenarc on it and afraid it will swing around, did you come up with a fix for the 19 inch one??
    2002 Jetta Tdi
    VIA EPIA MII-12000
    512 DDR
    250 gig Hd
    Usb Earthmate Gps
    Usb Linksys Bluetooth w/ext ant
    4 port usb hub
    2.5 dvd-cd
    Gyration Usb Wireless Keyboard/mouse
    Ps2 mini keyboard
    Xenarac 10.2" LCD
    Pcmcia Senao wifi 200mw w/dual ant's.
  4. #14
    Jul 2004
    Irvine, Cal
    Quote Originally Posted by Greasyrider View Post
    This is the one http://cgi.ebay.com/24-Gooseneck-Mou...QQcmdZViewItem
    Ok, only problem is that if you want to tuck your wires into the loom, it's gonna be really hard. What i did to solve this is cut it open, take out the loom, put in a bigger loom that i got from microcenter for 4-8 bucks and put my lcd wires in there which looks much better IMHO.
    Again this one doesn't swing easily, you have to much alot of force into it.
  5. #15
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    mine flexes at the mounting point. when you have 18 inches of a lever with a screen on the end of it, it sways on the bumps on the freeway.
    as for off road, i dunno usually i dont touch the damn thing and im moving all over the place too much to notice if the screen is.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
  1. where to buy a flexible mounting arm?
    By Fourgig in forum General Hardware Discussion
    Last Post: 02-21-2001, 07:47 AM
