Results 1 to 10 of 17
Thread: Making A door
    May 2006
    Making A door
    Here's my progress so far with the fabrication...
    www.angelfire.com/ny5/ofpureblood/mustang
    I took out the dash bezel cut it up in the back abit so the screen would fit ok, right now its held in just by pressue from the radio behind it and the plastic dash piece in front. I'm planning on extending the top and the two sides of the plastic about 2inches or so in hopes that it will provide some coverage from the sun so I won't get to much washout. My question is does anyone know how/where I can get some kind of door to cover the screen when not in use...im not in the greatest neighborhood so if it's covered less likely to be stolen.
    Anyone with ideas suggestions or anything at all im completely open to anything...thanks!
    Oct 2005
    This is what I did man.
    Ford Probe GT - Motorized LCD
    The cover is manually operated for now. Another idea might just be to make a fake cover from the front of a stock radio. Hold the cover in with magnets when you park.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i would look into the scion (sc?) i dunno...the sporty looking scion. or the 350z and see if you couuld modify the doors they use into your ride
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jul 2001
    Scion tC is what Scott means. The door SUCKS. When I was installing sat radio in my girlfriend's the stupid spring popped off no less than 3 times.
    I think Yev's workin on building some sort of roll-up door.
    May 2006
    well that probe is quite the installation but i have the same problem with that as i do with stealing a z's door and using that...i dont have the space behind it to have room for a door to slide behind it...
    Dec 2004
    Los Angeles Ca
    you could always hack off an oem headunit bezel and fab a removable cover to cover up your screen. another thing you could do is make a blank plate to cover it up. i guess you could try to make some sort of shade that could unroll to cover things up. maybe you could use some nytinol (sp?) to automate it.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    when i first saw the title i thought you were making half doors for something... ( i need to stay away from the off road forums for a little while...)
    anyway, the great thing about a door that doesnt go into the dash all the way, is that it provides a sunshade for your screen, we all know how ****ty they look in the sun, unless you have a trans like scott above me... lucky
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    May 2006
    how much is a trans?
    well i was thinking of using the two extensions on the side to form some kind of door that would fold over it but i duno how i could do it cuz theres no place to slide them into the dash to make them smaller and if i make them big enough to cover the whole screen they will be huge sticking out of the dash.
    I thought of the magnet idea and put my old radio bezel over it but wont the magnets fuk **** up.
    Quote Originally Posted by seanz0rz View Post
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by V6Stang View Post
    http://store.mp3car.com/ProductDetai...Code=MON%2D010
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Oct 2005
    If you don't have room for the door in the dash..I would say go with the "faux" front approach. If done right can look great.
    Another option would be to put slides on the side of the screen and have a door that splits in the middle (or multiple times) and you could lift it up. Imagine a sliding closet door hung vertical instead of horizontal.
  1. Water inside door panel!
    By Spencer in forum Car Audio
    Last Post: 09-28-2006, 09:17 AM
  2. door popper solenoid installation
    By i3igmind in forum Hardware Development
    Last Post: 03-29-2006, 12:21 AM
  3. Door panel question
    By mikemerrill50 in forum Fabrication
    Last Post: 10-10-2005, 11:31 AM
  4. self destructing $900 door actuator/ toyota sienna
    By turbocad6 in forum Off Topic
    Last Post: 09-24-2005, 07:59 PM
  5. MediaEngine Skin making
    By liquid_smoke in forum ME Archive
    Last Post: 09-13-2003, 08:45 PM
