Results 1 to 10 of 15
Thread: DJiK's Ported Subwoofer Enclosure
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Cool DJiK's Ported Subwoofer Enclosure
    This is my second time building a box.
    The Specs:
    • 2 Cubic Feet
    • 2 10" Deep x 3" Diameter Round PVC Ports
    • Tuned to 40 Hz
    • ¾" MDF
    • 65° Angle (to fit behind the back seats)
    • Amplifier Shelf
    The Pictures:
    From this:
    To this:
    Testing the Subwoofer:
    Done Deal:
    Up Next:
    • Installing and Testing Subwoofer
    • Mounting Two Speaker Terminals (1 per coil)
    • Test Fitting in the Trunk
    • Carpeting the Box
    • Securing Everything in the Car
    Let me know what you guys think!
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Jul 2001
    Those ports have a REALLY high risk of being noisy. Don't be surprised if you get some whistle.
    Otherwise it looks great.
    Apr 2005
    Quote Originally Posted by Shadow View Post
    I've checked everything with WinISD. The RMS air velocity should peak right under 109 ft/s at an input signal of 500W. That's under 10% of the speed of sound (1,116.4 ft/s), so I think I'll be fine.
    I'll let you guys know how close to reality that theory is.
    Jul 2001
    Well, last time I blew across the top of a coke bottle it made a noise and I'm WAY under 10% of the speed of sound.
    Apr 2005
    LoL.
    I see what you're saying.
    I've tested the box with the sub in (an Audiobahn AW1206T) at home and it worked wonders! It rattled the **** out of the garage! The air was felt 3' away from the ports.
    I'll bet I didn't even feed 100W of juice to it during the test.
    Anyway, the pics are to follow later tonight. -- Uploaded.
    Then it'll be paired with the correct amp and tested inside the trunk of a small Japanese car. Hmm...
    That should be fun!
    Jul 2001
    Yay, crappy sub.
    Newbie DCU1976's Avatar
    Jan 2005
    WinISD
    Did you use WinISD to build the shape of your enclosure. and what did you use to mak up the 3D drawings? looks good!
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Quote Originally Posted by DCU1976 View Post
    Sketchup??
    Failure is not an option....
    It's installed by default on every version of Windows.
    Apr 2005
    As BarryWoods said, all of the 3D drawings were made in Google SketchUp! (it's free, click here to download). After drawing the rough sketch I checked the dimensions, parameters, and properties in WinISD. Then I confirmed with SketchUp to see that it's actually buildable.
    Jan 2005
    Thanks!
    Thanks! Off to 3D modeling I go!
  1. Audi TT coupe Subwoofer and amp enclosure
    By eric545 in forum Car Audio
    Last Post: 10-12-2006, 03:51 PM
  2. Replies: 28
    Last Post: 01-17-2006, 07:58 AM
  3. subwoofer enclosure design software?
    By urafreak in forum Car Audio
    Last Post: 03-18-2005, 06:00 PM
  4. How to secure a subwoofer enclosure?
    By SwapMeet in forum Car Audio
    Last Post: 02-15-2005, 08:31 AM
  5. Subwoofer Enclosure Q-Value ???
    By Raas in forum Off Topic
    Last Post: 05-22-2002, 08:23 AM
