Results 1 to 10 of 20
Thread: help with MDF fabrication please....
    Jul 2006
    heres my problem: i have a 2005 Dodge Neon SXT and am trying to make MDF speaker rings to replace the plastic.
    now i have 3 options ive thought of. first option is use MDF and build that it up to the correct height, then cut and sand it to the correct angle and dimensions. Option 2 is build up MDF to that thickness, but leave it flat then when the speaker is mounted have it flush with the plastic door molding, once thats done cut a hole in the plastic molding and use the speaker grilles to cover the hole in the door so all you see is the speaker grills. option 3 is to make circular rings and glue em together vertically, then make a bigger MDF ring that fits ouside the smaller rings at an angle (kinda worried about the integrity of this option though)
    btw its about 3 inches, 1.75 above the flat part, and 1.25 below it, and i got 1/2 inch MDF board for these (gonna use 3/4 for sub)
    Jul 2001
    If I were you I wouldnt waste time building that up with mdf, Id just go ahead and bang it out with fiberglass. Can I see pictures of the door panel/kickpanel where the piece is going as well as the gutted frame of where its going. I may be able to help more with those pics. Thanks
    Jul 2006
    i thought about glassin it also... i just like the MDF
    Oct 2005
    Build a flat ring out of MDF, then either build some other rings, cut them in half - then use a band saw/table saw to cut them at angle. You end up with angle circular wedges. Use woodglue, screws to laminate it together. Pretty simple.
    Jul 2006
    thats what i basically was thinkin with the 1st option
    unfortunately i dont have many power tools atm... mainly hand power tools so its a little harder to do an angle....
    i might be able to get some other power tools that will help in a day or 2 but as of now i dont have the ability to do that
    Oct 2005
    Just cut the main rings then....use some wood blocks of various sizes to get the right angles. And glass it all together. Really I don't see you have many other options if you want it on an angle.
    You should really look at buying a jigsaw, only like 40-50 bucks for a reasonable one. You could cut accurate enough angles with it if you are careful, and sand down any imperfections.
    Jul 2001
    Why don't you just use that thing?
    Jul 2006
    b/c plastic isnt very rigid
    at least not that plastic.... and i dont want any vibrations transferred to the frame, or any other negatives b/c the plastic is not very rigid....
    i will prolly use that piece until i can get an actual enclosure for it...
    where are jigsaws for $40-50?
    Oct 2005
    Try Homdepot. Their low end models will be sub 50 bucks.
    Jul 2001
    Don't buy a cheap jigsaw. I think Bosch has a 6.5A jigsaw for $100 or so and it's got manual scroll control and a light. There's one model that Bosch has that uses the motor's fan to blow chips out of the way too.
  1. On-dash fabrication
    By binary.h4x in forum Fabrication
    Last Post: 06-30-2005, 12:08 PM
  2. Need to hire a fabrication expert
    By vladilen in forum Fabrication
    Last Post: 06-16-2005, 01:29 PM
  3. MDF Rings
    By Giwo in forum Fabrication
    Last Post: 03-23-2005, 05:42 PM
  4. Fake Floor Fabrication Question
    By thecommiser in forum Fabrication
    Last Post: 03-02-2005, 02:21 PM
  5. Custom Fabrication Work?
    By mattdisaster in forum Fabrication
    Last Post: 02-01-2005, 12:37 PM
