Page 1 of 7 1234567 LastLast
Results 1 to 10 of 63
Thread: My first carPC project with microATX mobo
    Constant Bitrate agniusm's Avatar
    Oct 2006
    Lisburn
    Hi folks. So finaly started my first car project and finaly registered with mp3car.com, so i'm newby.
    Spec:
    microATX m/b, 1.0GHz Celeron in diy alluminium case
    512 SDRAM
    M2-ATX PSU
    USB Bluetooth
    USB WIFI
    4 x USB2.0 pci
    1 right hand PCI riser card
    7" 16:9 touth screen
    Waiting some parts to arrive next week.
    Feb 2006
    Vancouver, BC
    nice case. Saved yourself a bit of money and it serve all the right purposes. Keep us up to date with the rest of your install.
    Maximum Bitrate Dragonknell911's Avatar
    Aug 2004
    out of curiousity what is that grey cable / connector to the right of the motherboard for?
    REBUILDING!!
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    the case is nice indeed, question is about powering solutions
    Yev
    R. T. F. M
    Oct 2006
    Lisburn
    Well that lead is for reset and power button as i donít like the idea of switching PC on/off automatically. I will try auto but donít think I will like it.
    As for the case I found Maplin selling them under £10.
    The case is 300x250x50mm.
    I will use M2-ATX 160W power supply which fits nicely near m/b. I have measured how much power the computer draws from mains and with BT, 5.25" DVD, 40Gb HDD it was taking ~130Watts. I will scrap that dvd cause I will have a wifi for downloads from my main computer.
    Now, some of the people here are making amazing bezels for LCDs. I want that too. Have to figure out where in my tiny saxo .
    Any way last night made some adjustments in case. I have placed 2 grills for the air to come out.
    Any one knows how to paint aluminium?
    Thanx for replays...
    Aug 2004
    uhmmm same as you paint anything else.
    Start out with a coarser sand paper ~200ish grit
    sand until all of the previous paint / glossy coating is removed
    then sand with finer sandpaper until its rather smooth
    then prime and wet sand with higher grit like ~800ish
    prime again and wet sand again
    then paint i use rustoleum paint for metal) (not sure if its available where your at)
    then wet sand with 800 grit, then paint again
    then clear coat if you want.
    REBUILDING!!
    tja
    tja is offline
    Aug 2005
    sydney, australia
    if u want a good finish on aluminium you will need an etch primer. aluminium isn't really the same as any other metal.
    2005 Nissan Xtrail
    DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
    worklog
    Oct 2005
    Mumbai, India
    you could get it anodised
    Aug 2004
    Its how I painted my aluminum case, and it worked perfectly. I'd post pictures of it, but it got scratched to hell during the process of installing and removing it about a hundred times.
    you could get in anodised
    considering he made his case himself for less than 10 pounds, im guessing he would'nt want to pay more than that to get it painted.
    REBUILDING!!
    Oct 2006
    Lisburn
    Hi,
    Yea, that was a stupid idea to paint it Dragonknell911 as i got it for 8£. Basicaly PC will sit behind front bezel and will be hidden.
    Well, i have got bits to mount lcd and DVD in front bezel. Manual on How-To: Recessed Screen and DVD Drive. Bought panel for 8 quid and DVD for free It was'nt working so fixed it Dont ask how i did that, dont have a clue
    Still waiting on my bits to arrive (LCD,PSU,Riser card).
  1. 2005 Saturn Redline CarPC / Audio project
    By sirpilsofd in forum Worklogs
    Last Post: 04-22-2006, 04:41 PM
  2. 2000 VW Passat GLX V6 2.8 CarPC Project
    By bluetoothxp in forum Worklogs
    Last Post: 04-06-2006, 03:46 PM
  3. FS: EPoX MicroATX AMD Mobo
    By Emo in forum Classified Archive
    Last Post: 01-31-2006, 11:12 AM
  4. Replies: 0
    Last Post: 01-25-2006, 01:38 AM
  5. perfect project for sale, lcd, mobo...
    By Shaggamuki in forum Classified Archive
    Last Post: 10-31-2001, 05:24 PM
