Results 1 to 9 of 9
Thread: Help with Nissan Versa
    May 2005
    So i want to make a box for my screen that will come down from the top of the dash into the center consol. I have made a box out of wood and it fits well now I am wondering what should i use to make the real box. I have read that bondo is good, but I have also read that it will crack. Any ideas? Here is a pic before and also a pic of what I would like it to look like. Thanks guys!
    Mar 2004
    Maryland/NOVA
    If you don't mind replacing the stock HU...
    I would remove the stock HU, put the screen in it's place and modify the cubby hole to fit an aftermarket HU.
    Good luck!
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    ditto
    May 2005
    i would do that
    But, I like how the Stock HU has the Bluetooth and the steering wheel controls. I thought about this idea and i think i want to try it with the stock HU. Do you think bondo would hold up though?
    May 2005
    is there anything better the bondo for this?
    Aug 2006
    Valencia, CA
    Way to extensive if your thinking about doing the whole thing in bondo. Bondo is a body filler, designed to fill in smaller dents, cracks, seams etc. Then you sand down the bondo to match the surrounding material.
    An example for your situation would be, if you made the piece with wood and fiberglass, then used bondo on the fiberglass to help get a perfect surface.
    Sep 2006
    duramix 4040 is the best bet for bonding and adding strength.
    Oct 2006
    Bondo is not structurally sound. Use fiberglass, epoxy, or possibly bondoglass. Dependig on the size you could use wood or plastic.
    May 2005
    Update!
    so its been in for about 2 1/2 months now and its works great
    I am going to redue it when it gets warm out, i needed to sand it a little better then i did, but other then that it is great, Thanks guys for all of your help!
  1. Nissan Versa
    By landonb16 in forum Newbie
    Last Post: 01-25-2007, 03:31 PM
  2. 85 nissan want computer to read gauges
    By Bigrick31 in forum General MP3Car Discussion
    Last Post: 07-11-2006, 04:14 PM
  3. Nissan skin
    By djR1SpecV in forum General MP3Car Discussion
    Last Post: 01-11-2006, 11:25 AM
  4. new nissan software?
    By dim-8 in forum Software & Software Development
    Last Post: 02-15-2005, 08:19 PM
