Results 1 to 7 of 7
Thread: Quick question
    Oct 2006
    Quick question
    I took my dash bezel off to attach my lilliput faceplate to it, cut it where I need to etc.
    My question is this. The bezel was previously painted by me, twice, so there are quite a few coats of paint and about 3 clear coats on it. Do I need to sand this piece completely down to the original plastic or just rough up the paint really good before I epoxy my monitor housing in place and bondo the correct shape?
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    ask yourself this: would you use paint to glue anything together?
    let your structure be your structure and your finish be your finish.
    Oct 2006
    Alright I'm guessing that was a roundabout way of saying I need to adhere it directly to the plastic.
    Is there any quick way to remove the paint other than sanding? Soak in paint thinner?
    Jun 2006
    Denver, CO
    i'd be careful with that since the same solvents that will clear off the paint are the ones that people use to dissolve ABS chips into sludge. Your best bet is sanding.
    Jul 2001
    Just sand it down to the plastic where you're going to attach the monitor.
    Also, sandblasting.
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    Quote Originally Posted by GoHybrid View Post
    i thought that it would only dissolve in fiberglass hardener,
    BTW if there are cheaper solvents out there to make sludge please make a recommendation i have a load of ABS plastic i sawed off my door panels, and trimmed off the dashboard
    Yev
    R. T. F. M
    Nov 2005
    Chicago
    i would sand, you don't have to sand the whole thing just the area where the action will take place
    other than that acetone will take it right off.
    R. T. F. M
  1. Quick Question About Grounds
    By jzgt in forum Car Audio
    Last Post: 01-29-2005, 06:59 PM
  2. Quick question for any other members (LCD)
    By septicdeath in forum LCD/Display
    Last Post: 01-11-2005, 06:59 AM
  3. Subwoofer boxes / cases - quick question
    By Pabs in forum Car Audio
    Last Post: 12-02-2004, 03:24 PM
  4. Quick question on kiosk
    By Gavc in forum General Hardware Discussion
    Last Post: 11-10-2004, 10:16 PM
  5. quick question about dc voltage
    By cdm in forum Power Supplies
    Last Post: 03-05-2004, 04:19 AM
