View Poll Results: Q: Should the bezel have the LED hole drilled?
Voters
56. You may not vote on this poll
  • Yes
    26 46.43%
  • No
    30 53.57%
Page 21 of 31 FirstFirst ... 1112131415161718192021222324252627282930 ... LastLast
Results 201 to 210 of 303
Thread: VW Golf R32/Anniversary Aluminium Xenarc 700TS/TSV/YH/YV/TSH/TSU bezel
  1. #201
    Mar 2007
    Quote Originally Posted by strohj View Post
    yes.. I was waiting till we get it... but you got first dibs on it
    Sweet!!
  2. #202
    Mar 2005
    new updates?
  3. #203
    Constant Bitrate Jon-G's Avatar
    Jun 2005
    Chesterfield, UK
    Hi Guys,
    Sorry for the delays in posting iv been jetting around again!
    I have been repeatedly chasing the engineers, and the latest update I have had from him is that they have found another finishing company to do the graining using a different method (mopping).
    He is sending a sample off to them on Monday so Im afraid we're back to playing the waiting game for the time being
  4. #204
    Apr 2007
    Mounting points in the back.
    All,
    I opened my 700TSV and took some measurements of the mounting points and sketched it up in 3D.
    If you want to manipulate in 3D load the following 3D XML viewer and then open the .3dxml file in the attached zip.
    http://www.3ds.com/products-solution...-all/3d-xml/1/
    The zip also contains an IGES and STEP file for your CAD program of choice.
    All of the holes in th back look like a standard metric M3 thread.
    Attached Files Attached Files
  5. #205
    Apr 2005
    Cheese and rice! This is taking 4-EVER!!! Should be worth the wait though.
  6. #206
    Nov 2006
    Raleigh, NC
    Quote Originally Posted by gb_r32 View Post
    Thanks gb_r32... so how can we get the stand-offs attached to the bezel? Glue plastic ones on there? Drill a small hole and thread it for M-F standoffs? I guess we'll have to see when we get them. It's good to see someone thinking about how this will work. A bezel by itself isn't a 100% solution.
  7. #207
    Jun 2005
    Chesterfield, UK
    Guys Ive received another sample finish today and it isnt upto scratch Iv just spoken to the engineers they have another sample going out to me today that hopefully will be good enough to give the thumbs up to and get the 20 finals finished.
    gb_r32:
    Thanks for the hard work mate, but doesnt the panel itself connect to the original bezel using four squared off 'S' type plates?
    Would you mind having a look while u have ur xenarc open?
    TIA
    Jon
  8. #208
    Mar 2005
    JON:
    it uses both the squared of "S" things and the standoffs you see in his drawing. The "S" type brackets attach to these standoffs.
    __|ŻŻ
  9. #209
    Jun 2005
    Chesterfield, UK
    Guys,
    The second sample has been approved, the definition on the edges is nice and sharp and the finals are being done as I type.
    Sux89:
    Do you think it would give a stronger hold if we remade the s brackets so they connect straight to the back of the bezel? I think if we have to attach stand-offs to the bezel , then attach the existing s brackets to these that it would give more flex than just making new taller s brackets?
    ll have a much better idea once I get my xenarc apart, which should be soon its about bloody time!
  10. #210
    Nov 2006
    Raleigh, NC
    Quote Originally Posted by Jon-G View Post
    Guys,
    Finally! - Thanks Jon!
  1. Xenarc 700TSV 7'' touch screen
    By krazymarine in forum Classified Archive
    Last Post: 09-20-2006, 10:55 PM
  2. 98 Accord with Xenarc 700TSV bezel fabrication
    By Dracord in forum Fabrication
    Last Post: 02-07-2006, 11:35 AM
  3. Mounting Xenarc 700TSV in custom bezel
    By blackflux in forum Fabrication
    Last Post: 09-11-2005, 07:13 PM
  4. Xenarc 700TSV / custom e46 bezel mounting
    By zaid175 in forum Fabrication
    Last Post: 06-13-2005, 06:05 AM
