I almost looks like run of the mill hot glue but I am not sure it could be some plain plastic epoxy
Hello guys I would like to stick my monitor like the one on this link
2001 tacoma install
but I'm not sure what material I got to buy, right now I got on hand
J-B WELD
http://images.google.com/imgres?imgu...lr%3D%26sa%3DN
LOCTITE EPOXY IT'S NOT EXACTLY THE SAME COLORS OF THE ONE THAT I HAVE BUT THE COTEINER IS THE SAME.
http://images.google.com/imgres?imgu...l%3Den%26lr%3D
IT'S NONE OF THOSE IS THE BETTER ONE CAN ANYONE OF U PUT I PICTURE OF WHAT SHOULD I USE SO I CAN GO TO THE STORE AND BUY IT, I will Apreciate that. Just to let u know guys I ask for a picture because I just got 1 1/2 living in usa and it will be more easy for me going to the store and know exactly what I need.
Thanks.
One of the best way to learn is making mistakes, But much better when you learn from someone else mistakes
Can somebody please tell me what is the best material to do what I one??
bump for answer! i want to know what type of glue used on that project also.
dunno what kind was used on that proj. but i use the Loctite stuff, works great
plastic weld epoxy
Its made by Permatex PermaPoxy, It Says Plastic WELD 5 Min Epoxy on it
Pinkish/black package I believe, White label, pink text
3-4 dollars a tube, I have one tube on my desk right now
Kragen has plastic weld also(about $6). I recently used on my project and it's very solid. dries in 10 min so mix little bit at a time. sand any paint from the plastic that you want to weld and it will be a permanent bond.
