Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 47
Thread: Worklog: Fiberglass sub box's
  1. #11
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    Quote Originally Posted by Shadow View Post
    One layer of fleece is as strong as 3 layers of mat.
    yeah and it cracks for no reason in temperature changes, if it was infact that strong nobody would bother matting as well
    Yev
    R. T. F. M
  2. #12
    Jan 2006
    why is your name SexySamSam?
  3. #13
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    Because he felt like it, why's your name laxplaya8513, what that have to do with his fiberglassing?
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  4. #14
    Nov 2006
    Wetaskiwin, Alberta
    Quote Originally Posted by Dennis5587 View Post
    /pwnd
  5. #15
    Jan 2006
    my name has everything to do with fiberglassing... are you new at it??? Lax is a type of weave for the fiberglass matting and Playa... is just playa, 8513 is the correct ratio you should be using resin to hardner and of course there is that 2 missing, that's all unimportant, it depends on how hot you want to mix the fiberglass. the hotter, the quicker it cures, etc etc.
    Now why is his name SexySamSam?
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Yevmeister View Post
    Yev
    It's not meant to be the only layer. It's used to get an initial shape. It's also commonly used in high end audio install shops all over the place.
    Jan Bennett
  7. #17
    Jan 2006
    hell, i not only learned how to fiberglass with fleece, i still to this day use it. It's great to use to conform to certain areas, then you can build strength with matting to get the rigidity that you need
  8. #18
    Nov 2006
    Wetaskiwin, Alberta
    fleece just seem's easier and it conforms to the shape the best with out having to worry about strips falling off.
  9. #19
    Jan 2006
    ?? the strips don't fall off when they get slightly resined.... even a small amount of resin will make it stick, when it's completely coated you can't even tell its' there...
  10. #20
    Nov 2006
    Wetaskiwin, Alberta
    Pkay, so we tryed to coat the fleece in resin but the elmers glue can suck my dick, it all came off so we then went to matt. We weren't allowed to do it in the garage because his mom said it smelled. It was a little to cold and the gravity took over before it could cure. We put a heat lamp in there and the first layer turn out ok. We are going to finish the inner shell tomorrow.
    Sam
    I Pwn
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 04:30 PM
  2. Fiberglass Alternative?
    By FiReToY in forum Fabrication
    Last Post: 04-24-2008, 09:24 AM
  3. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 03:03 PM
  4. 03-05 Honda Accord Fiberglass False Floor...WIP
    By 98EXL in forum Fabrication
    Last Post: 03-20-2006, 09:11 PM
  5. Replacing Dash Piece: Fiberglass or Wood?
    By fatejd in forum Fabrication
    Last Post: 01-17-2006, 12:02 AM
