Page 5 of 5 FirstFirst 12345
Results 41 to 47 of 47
Thread: Worklog: Fiberglass sub box's
  1. #41
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by Shadow View Post
    If you want to avoid lots of sanding do the fleece as the first layer and then do the fiberglass from the back.
    ehm... and whats the difference from this and putting a layer of some fine cloth as the final layer... should get pretty smooth!
    Swedish site for CarPC's
    http://www.bilpc.info
  2. #42
    Jul 2001
    It's way easier to get something smooth to start with than to lay something over the top of something bumpy to get something smooth.
  3. #43
    _
    Mar 2004
    Little Elm, Texas
    Fiberglass is rarely laid in a super smooth form unless you use a vacuum bag.
    Adding a layer of some kind of cloth over the top woll do nothing to even out the discrepencies in texture and height, it will only accentuate them.
    Applying glass/duraglass to the back side of the fabric is a trick that has been used for ages in fabrication. it gives the same benefits and requires a fraction of the work to finish it out.
    Jan Bennett
  4. #44
    Nov 2006
    Wetaskiwin, Alberta
    Okay, well today we got another two layers on and the shell poped out, tomorrow we are going to mount the speaker rings a stretch the fleece over then wait intill anohter nice day and lay some matt down. I will have pictures up tomorrow.
    Sam
    I Pwn
  5. #45
    Jul 2001
    Hey, Sam knows Fiberglass Matt too I haven't seen him around in a while.
  6. #46
    Feb 2007
    hi
    i wanted to make a box for a 10" w6
    i made the back and out of 3/4 mdf and was planing to make the top[ a front out of fiberglass.
    Could anyone tell me what the best materials would be to use and where to get them?
    thanks
  7. #47
    _
    Mar 2004
    Little Elm, Texas
    Fiberglassing Tips?
    stickies are your friends.
    Jan Bennett
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 03:30 PM
  2. Fiberglass Alternative?
    By FiReToY in forum Fabrication
    Last Post: 04-24-2008, 08:24 AM
  3. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 02:03 PM
  4. 03-05 Honda Accord Fiberglass False Floor...WIP
    By 98EXL in forum Fabrication
    Last Post: 03-20-2006, 08:11 PM
  5. Replacing Dash Piece: Fiberglass or Wood?
    By fatejd in forum Fabrication
    Last Post: 01-16-2006, 11:02 PM
