depends on what kinda pieces you plan on curing and what finish if your just looking for small parts You can run a 1500w setup.
well it's that time again, gotta finish project cold to work in the garage
so i am trying to get few heatlamps, i found few 90w -120w lamps in the home depot, put in the fixture, well on enough burn i guess
then i did some search, people recommend infrared lamps, and i found a lot of them out there, and having do i dea how many watts i need i decided to ask you guys
Thanks,
Yev
R. T. F. M
is there any alternative to heat lamps, that draw less energy
i got kicked out by my condominium association for indericting killing my neighbors from fumes in the parking garage.
my friend is going on vacation, so will let me use his garage for 2 weeks, his garage has only 20 amp curcuit
Yev
R. T. F. M
what are you trying to cure exactly?
resin, cause its like 39-45 degrees in his garage or 5-11 Celcius
resin would not cure properly
Yev
R. T. F. M
you might try laying up some insulation around your garage... if you can target the more troublesome spots like the garage door or exposed concrete, you might be able to raise your ambient air temps a few degrees. that way you don't need as much heat lamp power, and you don't have to worry about heating your FG projects too much or unevenly.
well, i live in the condo, and my friend left on vacation for 2 weeks, and let me use his garage
Yev
R. T. F. M
I wouldnt recommend using lamps directly on what you are trying to cure but rather try to raise the temperature of garage itself. You will get better results that way, that isnt to say that you cant use lamps, you just might get hotspots which will make your work harder for you.
try building a type of box/oven out of some type of insulation with heat lamp(s) directed into it. That way you are paying to heat the entire garage but rather a small area to get the same job done
