Results 1 to 10 of 18
Thread: How to mount an amp to a rear seat? Security in mind...
    Jul 2004
    Irvine, Cal
    Hey guys, i have a problem and I searched and couldn't find a real helpful solution...
    Problem: The rear seat of my integra has pretty flimsy sheat metal and blank spots (where there isn't metal at all). Also there is a very limited space where I can mount the amp (upper right corner, drivers side rear) because everywhere else will hit some part of the interior.
    I have already installed my amp in the behind the rear seat, 3 of 4 screws felt like they held tight + I added special glue but I came to find out today that all of them fell right out and so did the amp. The screws that i'm using are flat ended special security torx screws, the reasoning for this was to slow down thieves.
    Solution? What do you guys suggest to hold up the amp with these screws? Or to hold up the amp with security in mind?
    I can't just put wood in the back as the a thief can just unscrew the wood (philips screws)...
    Thanks!
    Nov 2006
    United Kingdom
    I know it means alot of work and is no use if your spair is in the boot but have you thought about making a 'fake' floor out of carpeted MDF. Would probley be the best way of hinding it aswell.
    Hope this helps.....good luck.
    Come on Peugeot....I want to fill you with noise!
    Jul 2004
    Irvine, Cal
    Quote Originally Posted by sheepy View Post
    Yeah i thought about that but since i've already mounted everything in the rear seat with the correct wire lengths and i do have a spare, i couldn't do it. I don't want to extend the 4 ga wires and all the others (mind you this is a 5.1 amp = alot of extensions lol) so no go...also I rather have it hard to steal than to hide although both are preferable in other cases.
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    well you can also do some build around the seat, with the sheet metal and carpeting. also see how deep can you chop in, and the maybe it will just gou out 2-3 inches, make a frame out of pine, (don't go with mdf since it's thin construction it would break), it would also be lighter if you go with pine.
    then take a sheetmetal, if you can't affor that do with thicker acrylic sheet, attach it to the wood frame skeleton, carpet it
    you set
    Yev
    R. T. F. M
    Nov 2005
    Chicago
    and yeah por extra protection use some weird metric bolts, and screws.
    and of course amatuer don't steal, (they break) professionals do
    Yev
    R. T. F. M
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by HitmanZ View Post
    Those nuts/screws fell down (back out) because you didn't use locking washers.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jul 2004
    Irvine, Cal
    Quote Originally Posted by MatrixPC View Post
    Are you saying to put locking washers in the back of the sheet metal ? If so thats really hard to do... or are u saying to just put locking washers on the screw
    Sep 2003
    Beach City, Socal
    Really, I don't know how to explain it.
    If you use screw and screw it into sheet metal, you put a locking washer on the screw before screw into the metal. The washer prevent the screw from backing out.
    If you use nuts and bolds. The washer shoud go before the nut.
    This site explain better http://myword.info/sendword.php?lock_washer_1-a
    Apr 2006
    Saint Petersburg, FL & Flint, MI & Auburn, NY
    something I have found easy to do. Find the nut you are going to use. Mount it to the inside of the metal from the back seat and use structuring solder on it to seal it to the seat. Then mount and bolt. DONE.
    ___________________________________
    1996 Accord Ex Carputer
    Soon to come 2008 WRX 5-door Mac-carputer.
    Apr 2006
    Or go to home depot or someplace. Find those holdsters that you insert into a hole then screw a screw into it that causes the other side to expand keeping it from backing out.
  1. Replies: 94
    Last Post: 09-13-2011, 06:59 PM
  2. Replies: 10
    Last Post: 03-09-2006, 06:25 PM
  3. TFT mount Seat Ibiza
    By jord in forum Fabrication
    Last Post: 04-18-2005, 02:48 AM
  4. snake mount
    By fretboard65 in forum General Hardware Discussion
    Last Post: 04-05-2005, 11:41 AM
  5. how close can you mount a HDD to an amp?
    By powerslide in forum General Hardware Discussion
    Last Post: 12-10-2004, 04:32 PM
