Results 1 to 10 of 16
Thread: MY first attempt at fab *WIP*
    Variable Bitrate FyreDaug's Avatar
    Jan 2005
    Saskatoon, SK
    This is a dash piece for a 95 neon, and an 809GL:
    Ive still got some work to do, as thats only primer right now. Im going to get a truck bed lining, like a rock guard paint for texture to not have it a solid flush color, rest of the interior is OEM, I want it to look the same.
    Should have it done this weekend
    Oct 2006
    looks good, you obviously had a lot of sanding to do.
    Jan 2005
    Saskatoon, SK
    yes I certainly did, it was quite a bit of work. first I had to glue the piece at the top, at the right angle, then I just drilled a few little holes through it around, put 2 layers of fiberglass cloth, cured, lightly sanded the fiberglass (so no MAJOR highs/lows) then just went with body filler over top to fill everything in. I also set it in the oven for a while at about 75C before I primed. Its a trick I learned that Ive had good experience with. Not sure if it works or not, but it always turns out in the end, im afraid to skip the step thinking it may not be doing anything. But I apply paint when its warm, not hot like I just took it out, but the paint seems to cure faster (stronger too maybe?)
    Jan 2005
    Saskatoon, SK
    no other comments? I guess ill need more pics, but I only did another layer of primer and im buying some texture paint tomorrow
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i think it looks great. i am not a fan of the buttons (i remove mine and cover them up) but besides that it looks good from what i can see. have a pic of the stock piece?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jan 2005
    Saskatoon, SK
    no actually I dont, ill see if I can track one down on some neon forums or something. But its basically a double din stock deck that was in there. Had to cut out a few pieces before I could start fiberglassin
    Newbie Brent25's Avatar
    May 2006
    Melbourne SE
    that looks really good dude...id be interested to find out if that oven trick does anything though if anyone knows...i like it with the buttons left on...looks more OEM that way cos most stock installs have buttons anyway.
    Jan 2005
    Saskatoon, SK
    The way I see it with the oven trick, is it heats it, makes sure there is no water in it for sure (since I rinced it before I painted) and the surface is warmer than if its cold, thing expand when hot and contract when cold. So its like having all its "pores" open when I spray it and as it dries it cools down closing it together. Its theory anyways, and my paints have always come out good
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Brent25 View Post
    its funny how two people can see things so differently. i think that it looks more oem without the buttons. most oem's buttons are rectangular, uniform have large backlit print.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jan 2005
    Saskatoon, SK
    Yeah I know what you mean scott, but I didnt want to dink around with doing a auto-on mod, or relocating the buttons. It was simple and it fits really nice next to the shifter (just enough room for fingers) its auto
  1. First attempt at fab
    By Brent25 in forum Fabrication
    Last Post: 12-22-2006, 07:42 AM
  2. Archive
    By Bitoholic in forum Mobile Media Center
    Last Post: 09-21-2006, 06:59 PM
  3. I like being a Newb :) Fab work started..
    By Chillboy in forum Newbie
    Last Post: 02-28-2006, 04:13 PM
  4. '93 Jeep Grand Cherokee In-Dash LCD Fab Questions
    By J-Hood in forum Fabrication
    Last Post: 11-24-2005, 11:54 PM
  5. Replies: 2
    Last Post: 01-24-2005, 04:19 PM
