Page 1 of 8 12345678 LastLast
Results 1 to 10 of 75
Thread: fiberglass Subs
    Jul 2006
    new york
    fiberglass Subs
    I'm building a fiberglass sub, I'm not sure how many layers of fiberglass do i need. It's a 10" Subs.
    _
    Mar 2004
    Little Elm, Texas
    You're actually building a fiberglass subwoofer?
    This should be good!
    oooo- or are you asking how many layers of fiberglass you need for the enclosure you're building FOR the sub?
    Jan Bennett
    Jul 2006
    new york
    Sorry it's the enclosure for the 10" sub
    Jan 2006
    Quote Originally Posted by RedGTiVR6 View Post
    LOL!!! and to answer the question and not get off the thread course, generally you want to layer down minimum 3 layers and keep building up until the box no longer flexes. There really isn't a set standard of layers. Curvatures usually require less glass than straight areas. Lets say you have one straight wall, that will be your weak point and require more fiberglass than lets say a 90* angle... I just usually layer more and more glass over until it becomes rigid. And then i test volume and if it's off by too much, i'd make a fiberglass soup sludge and fill as much as possible until it's close.
    _
    Mar 2004
    Little Elm, Texas
    It also depends on the weight of the mat you are using. I'd prefer multiple layers of thinner stuff than a few layers of the heavy stuff personally.
    Jan Bennett
    Jan 2006
    ^^ as i was saying, there isn't really a standard, i prefer heavier mat w/ less layers, Red prefers the thinner stuff with more layers. Either way, it's all personal preference, i haven't had any bad luck w/ less layers/heavier, and i'm sure more layers with lighter sets of Matting would be more structurally sound, but for most boxes i've made, my way still works perfectly fine =P
    Jul 2001
    Thinner material soaks up resin more readily and is easier to lay vertically and upside down than thicker and therefore more resin heavy stuff.
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    when you are confidently ready to stand on it... you should be ready, I wouldn't stand on it though....
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Jul 2006
    new york
    I finished 6 layers of fiberglass mat and it seem strong, I could actually stand on it.
    Jan 2006
    lol, usually i would randomly test by putting pressure with my thumb around the box...but standing on it works too.... lol
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 04:30 PM
  2. Low-budget SPL Subs
    By SuprchargdMazda in forum Car Audio
    Last Post: 05-24-2006, 03:33 AM
  3. 03-05 Honda Accord Fiberglass False Floor...WIP
    By 98EXL in forum Fabrication
    Last Post: 03-20-2006, 09:11 PM
  4. Soundblaster not pushing my subs...
    By 3onDubs in forum Car Audio
    Last Post: 11-21-2005, 05:27 AM
  5. Help hooking up subs and amp? Need advice...
    By jedi7001 in forum Car Audio
    Last Post: 05-17-2005, 02:28 AM
