Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: 9.0" Wide LCD in 2005 Subaru Impreza WRX STi
  1. #11
    Nov 2006
    Romania
    Quote Originally Posted by Giuliano View Post
    Yeah, I tried the same (an 8.4" LVDS screen) in my 2003 Impreza WRX, and never really finished it.
    So I traded it in for a 2005 STi, and having found the 9" widescreen, I'm trying it again.
    An 8" widescreen would have actually been the perfect size, but none are available in the LVDS connection, and I didn't want analog VGA.
    I never found a real reason to go for a LVDS screen, at least in my case..This (800x600) it is more than perfect for the damn opening i have in the dash...even though i had to cut and "build" a lot. In terms of signal... well, it is connected thru a 5 meters long cable (custom made, double shielded) along with the touchscreen usb one, and works cristal clear.
    I am preety sure i would have never succeed to install a 9" into my dash
    I cannot wait to see your install once it is done. Fingers crossed!
    My second Subaru skin
    Full screenshots second skin
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  2. #12
    Feb 2004
    Quote Originally Posted by LYHTSPD View Post
    It is an 04, so it still has the manual climate controls. It should be the same as the 02-03 models.
    Ah, I know that layout well..
    I still have a leftover dash piece from my 03 where the radio mounts, so I'll take a look at the interior dimensions and see.
  3. #13
    Feb 2004
    Quote Originally Posted by mugurg View Post
    It's not really the signal quality, though that is one factor..
    A LVDS-attached LCD panel acts just like the kinds that are attached to a laptop.
    The video controller knows exactly what the physical resolution of the LCD is, so it can do nifty things like resolution scaling, such as scaling down 1280x800 to 800x480.
    It can also do a "virtual screen" trick - ie, your desktop resolution is 1280x800, but the LCD is 800x480 - move the mouse beyond the LCD borders, and the picture scrolls around with it.
    Although I'm not quite sure how a touchscreen panel would behave with that..
    In any case, I've confirmed that Commell can provide a custom BIOS to support 800x480, so for me it's only a matter of deciding whether I want a LV-675 Pentium M, or a LV-677 Core Duo / Solo.
    They even had a bios update out for my older LV-671 to support 800x480, which is perfect for testing purposes.
  4. #14
    Feb 2004
    8.4" LVDS as second display..
    A thought just occurred to me..
    I still have my original AUO 8.4" 4:3 aspect display that runs 800x600 over LVDS, with a touch screen, and it works fine. Plenty bright, too, with a touch screen.
    I can get a PCI Express adapter card for the Commell LV-677 to support a second LVDS LCD panel as another display.
    How cool would it be to add the 8.4" as a secondary display, contained in a ruggedized frame, and stored in the glove box or under the passenger seat?
    I bet I could come up with some kind of an armature to swing it up into view, and back down out of the way for storage..
  5. #15
    Nov 2006
    Romania
    nice idea
    your passanger will allways be happy )
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  6. #16
    Mar 2005
    You have some very good ideas. I was very tempted to try and get an 8.4" into my WRX but ultimately decided to wait for the time being and actually get finished. I am happy except for the screen being hard to read, but then I did not shell out for a transflective so I can't complain.
  7. #17
    Feb 2004
    After having read the Working with Foam thread by GoHybrid, I've decided to change my tactics a bit..
    Instead of trying to bend aluminum into a complex angle, I'm going to try carving some RenShape foam to fit the recesses inside the dash.
    The foam will be shaped and hollowed out to fit the LCD panel at just the right angle.
    After the piece is finished, I'll mold it in silicone rubber, and cast a final part out of polyurethane plastic.
    I'll also shape a new bezel out of a foam block, which will let me re-position the automatic climate controls about 1/4-1/2" lower, allowing for a better fit on the LCD panel.
    In the end, I expect to have a complete 2-part system cast out of plastic, and will be able to make duplicates for anybody who wants one... for a small fee.
  8. #18
    Jul 2006
    I like what I have heard and would like to subscribe to your newsletter Giuliano.
  9. #19
    Feb 2004
    Wait 'till I flesh out my idea for the second LCD panel..
    Up on the dash in the clock area, in some kind of housing that allows the LCD panel to flip up.
    This area, to borrow a picture from Pseudo Nim:
    That car is an '05 2.5RS, but the interior is mostly the same.
  10. #20
    Jul 2006
    The JDM navigation screen does the same thing. You may want to head over to www.nasioc.com and search for some photos to get some ideas.
  1. 8.4" LCD in WRX dash.
    By Giuliano in forum LCD/Display
    Last Post: 08-07-2010, 03:27 AM
  2. Replacement center "glove box" for 2000 Subaru Impreza
    By Arathranar in forum Fabrication
    Last Post: 10-05-2004, 03:04 PM
  3. Need LCD controller board from digital world wide
    By camarossguy2 in forum LCD/Display
    Last Post: 08-27-2004, 02:43 PM
  4. small wide aspect LCD?
    By Onyx in forum LCD/Display
    Last Post: 06-29-2003, 12:46 AM
  5. Replies: 4
    Last Post: 03-16-2002, 01:32 AM
