Results 11 to 20 of 23
Thread: Fixing my Bezel????
  1. #11
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If there is a wally world in your area, they should have it. Any other autopart place like Pep Girl, Kragen/Advance auto, Autozone also have it.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #12
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    i actually think i would visit a place called "Pep Girl" more often...
  3. #13
    Constant Bitrate Perrosky's Avatar
    Feb 2006
    NJ
    As you guys said I went to autoadvance "closer one to me" and I found the filler prime (thanks god) the Bulldog Adhesion Promoter I did not find it there.
    I sand the bezel again as u said GoHybrid and now I'm apply the firs layer of prime. Tomorrow sanding then another layer of prime until look as good as possible (feels good first time doing this sh...)
    1. Questios
    Should I use 600 sand paper to sand the prime or what number?
    The same I was using first?
    Thanks guys for follow my thread and help me tomorro I will keep u updated.
    If you want see my diagram no body tell me anything about it
    One of the best way to learn is making mistakes, But much better when you learn from someone else mistakes
  4. #14
    Jul 2001
    High-build primer FTW!
  5. #15
    Feb 2006
    NJ
    Quote Originally Posted by Shadow View Post
    I really don't under stand what you mean with that sorry
  6. #16
    Feb 2006
    NJ
    Hey guys I hope u all doing good here you got a picture sanding after first layer of filler prime, it helps allot to see where do you really need to sand, and I just find out why the left side got a difference between the right side it's because it's more in to the back of the radio bezel than the right so I think my bezel it's not gonna be perfect as yours, but I'm still gonna try to do the best that I can to correct that I apply a little bit of epoxy on that side now to try to make a trick to it I hope it works.
    all suggestions and comments accepted
  7. #17
    Jun 2006
    Denver, CO
    keep going man! you're doing well!
  8. #18
    Feb 2006
    NJ
    99 passat bezel ready to paint?
    ok. after add more epoxy on left top and right side sanded again, another layer of prime sanded again, another layer of prime and wet sanded with 600grit sand paper. I think it's ready to paint
  9. #19
    Feb 2006
    NJ
    600 sandpaper wet sanded.
  10. #20
    Low Bitrate Shidoken's Avatar
    Jun 2006
    looks very clean!
    i was just wondering tho, how did you take that whole frame out of your center console? i'd like to do the same.
  1. Volkswagen additional bezel for TMZ lilliput
    By judoGTI in forum Fabrication
    Last Post: 07-23-2007, 11:38 AM
  2. Fiberglassing Gauge Pod in Bezel *pics*
    By jmilin5931 in forum Fabrication
    Last Post: 10-04-2006, 08:04 AM
  3. 2002 Silverado Custom Dash Bezel
    By AZ_Silverado in forum Fabrication
    Last Post: 08-09-2006, 01:46 PM
  4. Ford Explorer Custom Lilliput Bezel LOOK
    By CDesigns in forum Classified Archive
    Last Post: 05-29-2006, 10:23 AM
  5. Lilliput bezel broke away from console
    By peecee in forum Fabrication
    Last Post: 03-31-2006, 06:49 PM
