I would be very interested in alot of little things.
make me a good battery terminal that can hold 3-4 connections of extra large 1/0ga cable and I'd love you
Very likely, I have several projects I would like milled!
Somewhat likely, it depends..
Not very likely, I don't have any uses for it yet.
Not likely at all for whatever reason!
I would like to gauge the level of interest for a custom CNC milling service that is targeted specifically at the CarPC hobby. Uses include custom cases, bezels, custom MDF parts and other one-off parts. I would also like to get any other ideas on possible products of interest to this community. What other features are most requested in a new (Ampie-like) case? Some say PCI card support, others say CD/DVD drive, or even a 3.5" drive. What do you think? What colors?
In terms of cost, we are looking to be as cheap as possible since we want to offer one-off parts. There will likely be a milling cost based on the size and complexity of the milling (fairly cheap). There will also be a materials cost to supply the aluminum, plastic or MDF that is milled. Finally, there will be a small design charge unless the CAD file is provided by the customer.
Some ideas:
Custom Bezels
Custom Milled Cases
Engraving on Plexiglass, Plastic, or Metals
Plexiglass Cutting and Milling
MDF Milling (Sub-Rings, etc)
Any Ideas?
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
i would be very interested as well. i just had a cnc lazer company make a control panel for me. service has been slow but i'm hoping for the best.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
I'm going to build a CNC machine within the next 6 months. I'd do stuff for people on the boards at a much lower cost than most places would.
I would love to see something similar to an ampie like case that supports a PCI card.
Or even a little bit larger version supporting a micro atx board with a PCI slot. Plastic or Aluminum.
I could also use some 3" speaker rings for a grill (metal preferably) and/or spacer rings (these could be MDF). If you are given dimensions would that be enough to go off of?
I have no idea what CNC machining costs. Could you give rough estimates?
System always under construction
60-120 per hour plus material costs normally
You'd love me?It probably wouldn't take a lot to make something like this. Would it have to physically clamp onto the battery? Or could it be like a breakout box and maybe have a thick cable between it and the battery?
We would be much cheaper, and again, specifically tailored to the CarPC market. Off the top of my head, a few MDF spacer rings might set you back $35? That's just a rough estimate, and for a set of 4 or so. It's not tough to make something like that, and the MDF required isn't that expensive.
Some sort of next-generation PC case is definitely on our list. We would need a LOT of input and suggestions though. Aluminum extrusions sure are expensive, and may be out of the question. It would have to be either milled or sheet metal, or maybe a combination of both. I like the idea of a modular case, this way it can be customized to fit certain parts (ie: a 2.5"HDD and DVD slot, or instead only a 3.5"HDD). Ideas? I need to drum up enough interest in this...
I think there is a lot of need, but of course, would be based on cost/price.
I don't think it could ever be a full time job for you, but a couple weekends a month, and I think you will have stuff to do, and be able to fund your hobby.
I know in the past I paid way to much to have stuff CNC'd out of plastic. I would have done it with you if you were cheaper.
Michael
M10k
My Car Pc Install
My Boat Pc worklog
Then your guy was good. I said 60-120, not 60 or 120![]()
