Results 1 to 10 of 18
Thread: Jimmys Digital Dash
    Nov 2006
    Jimmys Digital Dash
    i need yalls help in trying to figure out if i could fit a old jimmys digital dash into my 94 4runner?
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    i think you're going to need to supply some more information... pictures are worth a kiloword. Here's what i'd suggest: post a picture of this "digital dash", and post a picture of your 4runner where you want the dash to go. Then give us a better description of what you want to do with it once it's in there. Then people can help you better.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by GoHybrid View Post
    oh, and
    1.9in x 2.9in -- 47mm x 73mm
    Maximum Bitrate Meatballman's Avatar
    Jul 1999
    Hartsville, SC
    The Jimmy dash would look something like this:
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    you would have to modify the dash extensively for it to just fit.. and then of course you would have to do extensive wiring changes for it to work...
    do you really like the digital dash that much that you would go through all that trouble??
    I would rather spend the money on getting a newer car....
    Oct 2004
    NY
    hey man, back in the day, when digital clusters first came out, I used to do conversions... I've put an 84 corvette dig into a 83 riviera & I've put a 88 Beretta dash cluster in a trans am... those are the two that come to mind right now... I've done a few others too...
    it's not that hard, but can be a little tricky if your vehicle isn't compatible with certain things... for example the speed signal will probably be compatible, the tach will if there both 6 cyl's, the fuel gauge uses a certain resistance range from full to empty, so you have to check there both the same... temp & oil pressure readings may require swapping our sender units... the rest is just figuring out the wiring, high beam indicator, turn indicators, warning lamps etc...
    as far as physically fitting it, & making it look finished & not butchered, that's all dependant on your fabrication skills I guess...
    Dec 2006
    look at dakota digital (dakotadigital.com i think) for a dig dash, guaranteed to fit and work properly
    expensive, but easier than hacking up something trying to get it to fit
    bdr
    Oct 2004
    NY
    most of the time, unless it's a rod or something, they look cheap...
    a factory cluster swap really is a cool way to go..., maybe I'm just partial because I've done it before with amazing results.... you had to see the look on peoples face when they saw a then pretty new riviera convertable, with that multi colored corvette cluster in it... the impact was very high on that one...., I also did one of those corvette clusters in a 79 camaro... sweet I tell you
    now, I'm more into building a custom gauge panel with an lcd in it, but a digital swapout is still not as rediculous as you guys make it sound, & if done nice, can be real sweet
    it's really not that hard to do either.....
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If you can physically swap the 2, how about the electrical part?
    With the way you posting the question, I may suggest you scrap the idea. And if you still want to do it, look up other Toyota model that has digital dash to put it in your runner. Electronically, between Toyotas has better match than a GM to Toyota (unless it is a Prizm to corrola or Vibe to Matrix.)
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by turbocad6 View Post
    Yep.
  1. Fs: Custom Escalade Dash & Carputer!!
    By EsKALad in forum Classified Archive
    Last Post: 11-09-2006, 11:24 PM
  2. Digital Dash front end
    By jeep642 in forum Software & Software Development
    Last Post: 10-05-2006, 03:22 PM
  3. Pic + software based digital dash
    By lez in forum Hardware Development
    Last Post: 05-27-2006, 06:47 PM
