acetone? as in nail polish remover? do i just go out and buy nail polish remover or is there a place that sells acetone in a larger size?
home depot or lowes will sell it...over in the paint section.
Jan Bennett
Hi everyone, I need to vacuum form some parts in ABS with the Burlwood and titanium finishes. I have looked high and low for sheets of ABS with these finishes with out luck. I have seen just about any product you can imagine made from it but can't find a supplier. Does anyone have any info that could help?
Dar
Looking for a bit of help here too. I have seen some people hot glue a screen in place. I was looking for a better option.
http://www.mp3car.com/vbulletin/atta...8&d=1169355408
http://www.mp3car.com/vbulletin/atta...7&d=1169355399
http://www.mp3car.com/vbulletin/atta...0&d=1169355475
Here is the screen in the bezel.
Would the plastic weld work for adding mounting tabs to the bezel? I hope to do that so I can take it out for replacement if I want and not have to buy another expensive bezel and risk the melting of hot glue on a hot day.
Thanks for the help and advice as always.
also fiberglass hardener & m.e.k.
Yev
R. T. F. M
Thanks. I'll fab some tabs and give it a shot. Thanks for the help. Sounds like I want to sand where I am connecting the tabs too. I'll try to post back what happens.
I just wasnt really excited about hot glue. Hopefully this works well.
Is there something I'm missing here? I took a 1/2 tablespoon of tiny abs shavings and placed them in a ceramic cup, poured in about tablespoon of acetone and played with it for about 1/2 hour... they were just as hard as when I put them in, couldn't do anything with them... Am I just using the wrong plastic/abs?
Cheers...
Just to throw my 2 cents in here, I picked up Loctite for PLASTIC @ Loews and it worked great for securing plastic on plastic. Its one of those syringe type applicators where you must mix the two together. Loctite PLASTIC =![]()
