Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Best adhesive for bonding ABS to ABS.
    Dec 2006
    Ive been searching for 2 days on the best adhesives but can not find anything. Thats why I decided to ask the people on here who have had experience with ABS to ABS adhesion.
    I found this stuff made by UHU called "Airplane Glue" used to glue plastics. This stuff also slightly melts to plastics together and provides adhesion. I do not know the reputation of this stuff but would like to try it out. Is there better solutions out there?
    Feb 2006
    Vancouver, BC
    The best glue for ABS, is ABS. It's stable enough that if you were to melt it and combine it with the other ABS piece that it will form together. I saw on the board someone who melted lego pieces and used that as the adhesive. But as a product that can be readily bought, the stuff you're talking about should be good enough.
    FLAC evandude's Avatar
    Mar 2005
    Maine
    You can usually buy "plastic welder" at hardware/home improvement stores, it's basically an epoxy with strong solvent in it, comes in a twin-tube syringe just like most epoxies. It lists ABS on the materials it supports.
    guizai is right, if you don't mind a little extra work, using melted ABS is probably your best bet, you just need to chop up some scrap ABS into shavings (I used a big drill bit on some ABS and it made shavings very quickly), and then put them in some acetone. Play with the mixture until it comes out to your desired consistency. Make it in a squirt bottle, use it just like epoxy or whatever. This way, the entire work piece is made of ABS plastic so you shouldn't have problems with thermal expansion leading to cracks or separation like you can have with other materials.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    _
    Mar 2004
    Little Elm, Texas
    plastic weld works incredibly well, just be sure you throughly clean and rough up the surfaces that you are bonding.
    Jan Bennett
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    Plastic weld. I dont buy the one thats shown above, Had bad luck, it was brittle, just sucked in general.
    Had better luck with http://paint-and-supplies.hardwarest...te-651856.aspx
    That brand. found in walmart/autozone/checkers/advanced auto parts
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
    Jan 2006
    I used PVC cement to get the screen case to stay while I was doing the epoxying. It was flexible, but it held it there.
    Low Bitrate jnorion's Avatar
    Aug 2004
    Portland, OR
    For an easy quick version that will work decently well I used epoxy putty. It probably won't hold up under lots of stress but it worked fine to hold the screen bezel to the radio bezel so I could bondo around the outside.
    ~ Joel
    Mar 2005
    You only need acetone, no need for other products or ABS chips.
    Just brush acetone on both pieces, join them and wait 5 minutes.
    You will find that your two pieces now are literally one piece.
    There is not anything stronger for abs plastic.
    Mar 2005
    Maine
    Right, assuming the parts that need to be glued are already a nice snug fit. Plastic welder and/or ABS sludge come in handy when you need to fill a gap though, as is so often the case in carPC-related fabrication.
    eegeek.net
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
  1. My try at ABS sludging a xenarc
    By evandude in forum Fabrication
    Last Post: 08-09-2006, 02:20 AM
  2. How to bond ABS to lexan or plexi?
    By 01black_ac in forum Fabrication
    Last Post: 04-10-2006, 12:15 PM
  3. Salvaging my ABS sludge install with fiberglass?
    Last Post: 02-11-2006, 07:22 PM
  4. abs for molds?
    By scott_fx in forum Fabrication
    Last Post: 02-10-2006, 09:15 PM
  5. 100% ABS LCD install with texture
    By Snootch in forum Fabrication
    Last Post: 07-11-2005, 03:16 PM
