Doesn't "In-Dash" mean that your screen is suppose to traditionaly fit in a single din enclosure and go straight into ur dash???
Since you so helpfully pointed out how my "edges look horrible" (insert sarcasm here) over in my original thread, i thought maybe i would help you out with your climate gap.
Because i recently did the same project, i noticed that too and was able to fix it. After close examination of your pics, i noticed that there is a crack in your metra kit. This is caused by the dremmeling off of the pockets of the kit. If you look closely at the center of the insides of the metra kit, there is a crack which actually deforms the kit slightly. This slight deformation will cause the gap that you see between the climate controls and the kit.
Try removing your lilliput and pushing from the bottom of corners of the metra kit. Also, the climate control can actually wiggle a little. I found that pushing it upwards helps close the gap. Be careful because your metra kit is probably quite fragile at this point since your removed most of the plastic that kept it strong.
If this is still unclear maybe i'll post a pic of what i'm talkign about next time.
Good luck.
Can.
LinkBack URL
About LinkBacks
