Results 1 to 7 of 7
Thread: Oem finishing techniques
    Jan 2007
    I am going to be building a bezel for a LCD panel, there is a metra kit available for the car and i plan to simply use a strong adhesive or fibreglass to mount the LCD trim/bezel to the Metra peice then use some sort of filler such as bondo etc. to fill and smooth the gaps/holes. Is there a particular product/s that can be used to give me that semi-textured satin black finish after ive filled, smoothed, sanded, and primed the final peice?
    Cheers boys and girls....
    Jan 2007
    UK
    SEM Texture Coat is what you're after, and then possibly a dye if you want to change the colour. Available through Select Products in the US I think, although you can probably find it other places.
    Here's a piece I did with some, without dye: http://www.icecavern.com/forum/index...e=post&id=1100
    Variable Bitrate Spawn12336's Avatar
    Nov 2005
    Toronto, ON
    What kind of vehicle and what kind of texture pattern might help people in assisting you. I don't know of any techiniques, but i think that will help.
    "the universe has a way of balancing itself"
    http://i15.photobucket.com/albums/a3.../Webbanner.jpg
    Oct 2007
    Ohio
    3M 05911 Rocker Panel Spray for texture then for color matching.
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    ask turbocad6 for the specifics, but i think he just spattered the paint from the can and laid it on real dry to get the grainy ABS texture before laying down the final color. Part of the genious of that technique is that you can get that texture with any color you please.
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    There's also krylon fusion texture, check out my worklog (in my sig) for a pic of a close-up of the texture (page 5 is where the bezel stuff starts) it's a nice subtle texture closer matched to oem stuff. I then applied Krylon fusion satin black over that to get the color I wanted. Also, IMO it's better to use abs with abs (and not fiberglass and bondo.) Metra uses abs plastic and most screen bezels are abs, so this would be a WAY better bond, and wouldn't have the issues with cracking or warping due to dissimilar chemicals' heat expansion rates.
    They sell the krylon stuff at wally-world (wal mart) for about 4 bucks a can...
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    Mar 2007
    Central Florida
    You could always just sand blast the "finished" product to get the texture. Looks good and very OEM. Of course, that only works if the plastic is the right color.
  1. OEM Boards
    By DaRacerz in forum GPS
    Last Post: 08-10-2006, 10:03 PM
  2. OEM GPS mod. Writeup + Pics
    By IntellaWorks in forum Hardware Development
    Last Post: 07-04-2006, 03:59 AM
  3. Oem Gps Axiom Sandpiper Avalaible In Italy And Europe
    By slimmegane in forum Classified Archive
    Last Post: 10-08-2005, 07:49 AM
  4. OEM GPS Modules.
    Last Post: 03-08-2005, 07:29 AM
  5. OEM looking control--use power window switches?
    By telekineticfool in forum Input Devices
    Last Post: 01-04-2004, 12:06 AM
