Results 1 to 6 of 6
Thread: Any ideas?
    May 2005
    Any ideas?
    So far here is my design for the carputer case.
    The board itself is just under 4"x6" and the hard drive is being mounted underneath. I haven't pictured a fan yet, but there will be one.
    I plan on making the case out of Lexan (Polycarbonate sheet)
    Any feedback?
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    is there going to be a top to the case?
    Constant Bitrate jeffreyd_tx's Avatar
    Sep 2006
    Wilkes-Barre, Pennsylvania, United States
    I made mine from Lexan. Came out great. I was concerned about heat since this enclosure is under my passenger seat but it runs very cool. Mine is a uATX though which is much larger than what you have going on. My system has 2 x 2.5 HDDs. I have one mounted on the ceiling of the enclosure and one along the side. In the case, I also have a half height 9250 AGP video card and a SATA controller since my board has no onboard controller.
    I went by a local plastic shop and asked then if they had any scrap and they gave me a 2' x 4' sheet for free. It isnt expensive to begin with but I would check it out. Also, get the cement that is recommended for Polycarbonate to Polycarbonate, it works wonderfully! Good luck.
    May 2005
    Quote Originally Posted by jeffreyd_tx View Post
    Yeh, I don't think heat will be a problem once I get a little fan in there. Space is really tight as it is a powered passenger seat, but this should fit within a couple of mm.
    I picked up the polycarbonate sheet already, but I wonder if it would be better to have the local plastic shop cut it for me than to do it with my jigsaw.
    Yes it will have a top, I haven't added that to the drawing yet
    Mar 2006
    Colorado, but Canadian!
    For cutting plastic I prefer laser cutting. Some shops can do it for you really cheaply. It is probably what the plastic shops use as well for smaller pieces.
    just my $0.02
    1.9in x 2.9in -- 47mm x 73mm
    Sep 2006
    Table saw with a 40 tooth carbide blade worked great for me! Very smooth cuts. I need to get some pics up.
  1. Some ideas about simplifying the skin
    By predator1 in forum CF Skins
    Last Post: 07-29-2006, 05:43 PM
  2. Newbie Ideas
    By codyman in forum Newbie
    Last Post: 03-14-2005, 10:03 PM
  3. any ideas? 7.2 inch screen no TS
    By xdjxklusivex in forum Fabrication
    Last Post: 02-27-2005, 06:52 PM
  4. CarPC Brainstorming Ideas
    By Bugbyte in forum General MP3Car Discussion
    Last Post: 12-27-2004, 02:40 PM
  5. Mounting idea's for a Mazda RX-8???
    By glxyjones in forum LCD/Display
    Last Post: 06-08-2004, 12:29 PM
