Results 1 to 10 of 18
Thread: Now for something really different...?
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    if you have a hatchback, where do you put your subs?
    in a box behind the back seats?
    thats where mine are. one box, 2 subs, and a 5 channel amp on the top. one nice complete package.
    one that ruins the entire idea behind having a "psuedo-sationwagon-thing" where I can fold down the back seats to make a nice deck for, i dont know, big tubs of industrial mayo, tires, mattress? but w/e it'd be nice to not have my box take up the center of this folded down space.
    ive always wanted to move my subs to custom enclosures within the side-walls of the back of the matrix.
    there is probably 2-4 inches worth of space between that piece of plastic and the outer wall of the car. even more in some places a little more to the back.
    ive only seen custom enclosure how-to's on spare tire wells, and molded boxes. but nothing exactly like this, so im sort of stumped as to how to begin.
    should I remove the plastic piece, but only after ive attached, say, foam sticks to the back of the plastic that in various places give me a general contour of the metal outer wall of the car? (i have to wonder how id have access to do this without already cutting the speaker hole prematurely)
    seeing as how if i create a custom enclosure with the plastic away from the car, that the tolerances would be quite small because placing the plastic/enclosure piece back into place, the back of the enclosure must either rest upon (with foam or something to isolate vibrations, somewhat) or be a little be away from the outer wall.
    so maybe, you can see my problem(s)?
    (All done)
    iPad Mini 128GB, RF 600.5 amp, JL12W0V2, 8 Infinity Components
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i would just build out the area where you drew the boob so it's flush with the part that juts out. that'll giveyou a bit more clearance and you could make a nice cover with some grill cloth to make it look stealth. there was a thread posted not that long ago with some slimline subs that would also benefit you.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I'ma big fan of that location you picked. I did the same with MDF board in my trunk. (Every piece was custom cut and fitted.) There are ways to do it with Fiberglass. I don't have much experience in fiberglass, but the fabrication subforum has lots of good info on that.
    Aug 2004
    Floreeda
    how do I hold a custom enclosure to the plastic/car itself?
    (All done)
    Sep 2006
    The finished enclosure or while you are making it? You might want to ask this sort of thing in the fabrication forum if you mean construction techniques. I was always taught use as much wood for flat areas pieces and then use braces. Then fiberglass the pieces together. Every car is different. I'm not a fiberglass expert though.
    As far as the final result, braces where ever you can put them. If you can find a way to hide them that is the best. Mine I screwed/bolted right to the metal braces in my trunk from the inside of the box (this also keeps theivies from stealing it).
    Aug 2004
    Floreeda
    could we move this to the fabrication forum then?
    (All done)
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Have you seen mine?
    My Fiberglass Sub box
    I bought some velco from wally world to secure it. So far, working great.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Constant Bitrate mwmcginn's Avatar
    Dec 2006
    St Louis
    Quote Originally Posted by MatrixPC View Post
    Have you seen mine?
    That is nice. I would do something like that.
    Mike M
    2006 Accord VP Sedan
    My worklog
    http://www.mp3car.com/vbulletin/work...-dads-car.html
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    pics kinda large:
    see if qlogic makes a box for your app. or make one yourself.
    now ive been yelled at that it wont sound as good, but whatever, it sounds great!!!
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    Dec 2004
    Los Angeles Ca
    how does that blaupunkt amp sound? it's sucha pretty amp
    M10k
    My Car Pc Install
    My Boat Pc worklog
