do you have pictures of all components? regardless, those are probably all made from abs so i'd start with the original housings and graph them together. for the v1 display; to save space, you could replace the arrows with simpler led's (it'll be more stealth too) and just extend the wires from the pcboard to the holes drilled in an abs 'plate' then mount that then when you have the basic layout graphed together, then take the plastic piece over your steering wheel and graph that with the new panel that you had made. shouldnt be too hard
LinkBack URL
About LinkBacks
