Results 1 to 7 of 7
Thread: Screen Mounting Suggestion
    Jan 2007
    I need help in locating the screen for my Carputer. I have a Nissan Sunny 2005. I have attached picture of the car's driver end. Thanks in Advance
    Maximum Bitrate pepsibobby's Avatar
    Dec 2005
    Kaiserslautern Germany
    well it depends. Do you want to fabricate in a screen or use a single din flip out? If you want to fabricate it into the dash, that little lid thingy several peple have put their screens in there and had a mechanism to raise and lower it.
    Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
    Sep 2006
    Prolly a bit extreme and ambitious but hers what i think would look best
    Jan 2007
    Changing those climate control buttons would be a problem? Am thinking of doing this for the first time, and hence don't have any handson experience...
    Need all the advice i can get...
    Jan 2007
    Szeged, Hungary
    It depends, what you need. If that one is just an aux. display (eg. to search and start certain albums BEFORE ignition), your idea is good enough.
    But if you want to watch it frequently (I suppose so), I suggest you to put it at the level of the instruments or above...
    I personally think it is extremely dangerous to stare down while you are driving.
    Sep 2006
    Everyone does something for the first time sometime or nothing would ever get done. Heres what you do pick up any spare dash pieces u might be cutting up and use those that way its totally reversible. If u can manage to move the climate control down you would have a very classy install. Enough ingenuity and work and anything is possible.
    Jan 2007
    thanks for the moral booster. I am certainly doing a lot of research (for me its research) in that area, But slowly as and when i find the time....
  1. Playing full screen video only to rear screen
    By yossisibi in forum Centrafuse
    Last Post: 10-29-2006, 07:06 AM
  2. GPS suggestion: maximize screen real estate
    By aoLhaTer in forum Centrafuse
    Last Post: 03-12-2006, 08:48 AM
  3. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 03:02 PM
  4. Comps Specs and Screen Size
    By Rocky388 in forum Newbie
    Last Post: 05-31-2005, 09:37 PM
  5. Mounting Suggestion
    By dummptyhummpty in forum LCD/Display
    Last Post: 04-30-2003, 05:29 PM
