Results 1 to 6 of 6
Thread: Custom Case for Mini-ITX PC
    Aug 2004
    Bundaberg QLD AU
    I am new to carputers, and i am in the process of setting up my car computer...
    I have a Mini-ITX Mobo (Via M10000), 120Gb 2.5" drive, a laptop CD-Rom (which i plan to replace with a laptop slot load dvd-rom or dvd-rw), M1-ATX
    I also have a PCI right angle Riser card that takes 2 PCI cards... I am tossing up whether to get a "decent" sound card (which i am not sure what to get yet) and whether i got for a PCI WiFi card or just a USB WiFi Dongle...
    Anyway to get to the point... Now I am considering building a custom case to go under my seat (yes I have read the FAQ about not putting the case under the seat, but in my case i feel its the best place). I am wonder whether to build it out of MDF or metal (aluminium or stainless steel). I am thinking that MDF is probably the best option as i already have the tools required to work with it, and i have had a lot more experience with MDF (setting up my sub box and false floor in my boot) than metal (pretty much 0 experience). MDF is also cheaper...
    Is there any reason not to build the case from MDF?
    Has anyone got photos of any custom cases they have built that might be able to give me ideas for any good ways to build the case (other than just a straight retangular box)
    Mar 2006
    Colorado, but Canadian!
    veritas forge makes great custom metal cases for cheap. great cases.
    1.9in x 2.9in -- 47mm x 73mm
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    yeah...he has a great design that i showed him...i think i have to pass on it because my design wont do the case justice.... you should talk to him about it.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    .063" aluminum and you won't be sorry. Its all I use for fabricating cases. Lightweight, slimline, STRONG
    Variable Bitrate tigergibb's Avatar
    Nov 2006
    Snellville, GA
    I'm using fiberglass in the glovebox to mount my components.
    Constant Bitrate MrJamieR's Avatar
    Jan 2007
    Melbourne, VIC
    Hey Birdie just how much room IS there under the seat of the mighty Corolla Seca Conquest? Are you going to have the room for an MDF case? I would have thought that even if you use 10mm MDF you're going to run out of room in a hurry.
  1. Custom 1.6mm Thick Aluminum Carpc Trunk Case
    By LiquidKernel in forum Fabrication
    Last Post: 06-08-2008, 02:52 PM
  2. Keyboard language indicator extension plugin
    By tolisn in forum RR Plugins
    Last Post: 09-13-2006, 04:49 AM
  3. Replies: 14
    Last Post: 08-20-2005, 11:14 AM
  4. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 10:42 PM
  5. DC-DC car power supply for ITX case
    By mrandery in forum Power Supplies
    Last Post: 08-30-2002, 09:30 AM
