Results 1 to 10 of 14
Thread: Mounting computer components to a MDF box
    Oct 2005
    Here's the MDF Box, it's not too large but big enough to fit a few components inside of it. It's basically replacing my center cubby in my car.
    Any ideas on what I could use to mount possibly the motherboard, PSU and maybe other things that might fit in there? I plan on wrapping the box in some sort of material, preferably something that gives off little static. For mounting...is Velcro a logical solution?
    Elsewhere
    Get some standoffs from a local computer shop.
    How about the Wiki?
    Oct 2006
    Velcro is not a good way to mount electronics...
    Standoffs or angle brackets are your best bet. They even make brackets specifically designed for mounting hard drives
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i've used standoffs and aluminum spacers, both with great results. do it once and do it right... i'm still trying to learn that lesson though
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    or if you're cheap and lazy like me, you can take an old computer that you just have lying around, meaning to throw out, and just chop it up 'til you have the motherboard tray, screw that to the wood with the right standoff's on it, then screw your mother board on to that. You can even get the hard drive cage from there...
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by Dennis5587 View Post
    That is what I did... solid no flex surface for the MB.
    TruckinMP3
    Read the FAQ!
    Oct 2005
    Thank you all for the suggestions above. I've wrapped my box and just received some plastic standoffs today. I just have a few more questions. I'm going to put my motherboard, hard drive and possibly my power supply inside this box. Is it crazy to put so much in such a small area, especially with a 250W Opus.
    Pictures for reference:
    Just a few notes: I'm cutting out the back side of the MDF box to expose the motherboard connections. The box really won't be visible, it's basically just something to hold the components...hence the ****ty wrapping job
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    you way want to throw a fan in there too, just to keep everything nice and cool.
    other than that it looks ok.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    Oct 2005
    Quote Originally Posted by seanz0rz View Post
    Way ahead of you
    Mar 2006
    Colorado, but Canadian!
    Did you spraypaint fabric over it?
    1.9in x 2.9in -- 47mm x 73mm
  1. ANy general tips for mounting a hu in the glove box?
    By Bboy_jon in forum Fabrication
    Last Post: 04-08-2006, 02:26 AM
  2. F/S: JL 12w7 Subwoofer with box!!! Pictures inside
    By neema12 in forum Classified Archive
    Last Post: 08-29-2005, 09:45 PM
  3. FS: Car Computer Setup - Everything you need!! Pics Galore
    By EBoundEE in forum Classified Archive
    Last Post: 06-19-2004, 10:41 PM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  5. 250 watt subs affecting harddrive/other computer components?
    By DerekG in forum General Hardware Discussion
    Last Post: 05-13-2001, 09:22 PM
