5 Attachment(s)
Enclosing side door panel map pockets to hold 6 " Focal Access 165 CA1 Speakers
Calling all the fabrication masters of the hills from the nether region.
I need some assitance with ideas on how to go about integrating a set of 6" Focal speakers into my side door map pockets.
Here is the panel off of the car with the map pocekt mounted to it. By the way the map pockets are ABS and have 3 tabs at the bottom that fit into slots that are cut into the door panels at the bottom. Then there are 2 places for screws that thread in from the back. one on the top right corner and one on the top left corner.
http://www.mp3car.com/vbulletin/atta...6&d=1170551613
Another angle
http://www.mp3car.com/vbulletin/atta...1&d=1170551642
and another
The panel with the map pocket removed
The map pocekt itself from the front
The back of the map pocket
http://www.mp3car.com/vbulletin/atta...1&d=1170552541
The Focal speaker sitting upright in the map pocket from the back to show the depth of the speaker in relation to the depth of the map pocket.
The speaker next to the map pocket both sitting upright to show some more depth.
The speaker sitting face down on the map pocket in the upright poistion . This is at the rear of the map pocket. There is obviously not enough room to cut a full circle in the pocket to get it in.
The speaker sitting face down on the front part of the map pocket. Even less room here in the front to integrate it.
My thoughts are to somehow make the map pocket a bit taller with Fiberglass I guess and then cut the opening for the speaker. I guess I will need to cut some spacer rings that go on the front of the map pocket so that I will not have to cut out a section of the door panel right? Cutting the door panel with a hole would allow sound to filter in behind the door panel and not allow a closed enclosure. So do I just put dowels at the top of the map pocket and then stretch fleese over them to wrap the fiberglass and make a kinda map pocket box? Wont the rear edges seem like they are dropping and not meet the door panel in a perfect 90 degree angle ? Making it loook hooky.....
I need any and all opinions of how to make this look flawless and sound great.
Be specific and if possible diagrams are sooo helpful to gain an understanding.
Thanks ! I look forward to my first fiberglass fabrication and hope to grow in knowledge and technique along the way!
