Results 1 to 10 of 10
Thread: Fabrication for hire??
    Dec 2005
    Augusta, GA
    I have a 2002 Nissan Xterra and I was wondering if anyone knows of individuals/shops that can perform this type of work.
    I ultimately would like to remove the stock double din HU entirely. Then I would like to move the A/C controls to the bottom of the dash(nearest to gear stick) and have the touchscreen monitor at the top of the dash, right underneath the air vents.
    Any help or info is greatly appreciated.
    Variable Bitrate walstib's Avatar
    Jul 2005
    Atlanta, GA
    Umm... Where do you live? A shop in Miami, Florida, USA wouldn't help too much if you live in Florence, Italy.
    Your dash is probably pretty similar to mine, I have an '01 Pathfinder. It's not that hard to do the work, have a look at my worklog. I do not know the first thing about making fiberglass parts, but plenty of folks here do if you wanted to do custom fiberglass dash work.
    Carputer Project Status:
    0% - Mobo died on 2/17/08
    Check out the worklog for my '01 Pathfinder.
    Dec 2005
    Augusta, GA
    Georgia
    Actually, Im in Augusta, GA.
    Ive actually looked at my dash and decided to just replace the double din HU with the touchscreen. It seems that it would be hell trying to swap the A/C controls. I do have a big cubby space undernearth the stock HU that I could possibly use. Here are my dash pics.
    Jul 2005
    Atlanta, GA
    That sounds like a good plan. You might could put a radio and the PC in the cubby hole and even add a cover. There is probably a pretty good bit of room behind the panel.
    Variable Bitrate tigergibb's Avatar
    Nov 2006
    Snellville, GA
    I measured the cubby, and to fit a 17cm x 17cm mini-itx board down there, you would have to do some cutting and stuff. i'm not sure about the nano-itx boards. they may or may not fit.. i haven't checked. I have a 2003 Nissan Xterra. I already have all my parts to start fabrication.. I just need to figure out how I'm going to do it. My computer is going into the glovebox. I really wanted it in that cubby with a plexiglass cover, but I don't know if I want to cut apart the cubby or not. That would also be a sign saying STEAL ME!! I'm going to set up a home made alarm with magnets and keep relays with ultra loud 120db piezo's so if anyone tries to touch my PC, they will have some hearing problems .
    Jul 2005
    Atlanta, GA
    Nano boards are the size of a CD, 12cm square.
    Low Bitrate Super_dave's Avatar
    Sep 2006
    Quote Originally Posted by ignignokt View Post
    Hifi Buys in Duluth GA ask for Biscuit 7706229133
    the drive is about 2 1/2 hours
    Dec 2005
    Augusta, GA
    thanks
    thanks for the info..
    After reading a bit more, im thinking about just keeping everying as OEM as possible in the truck, without hacking up the panel. Im going to try to get a double din monitor/pc/pu and not have to do major mods to the truck.
    Dec 2005
    Augusta, GA
    Tigergibb...
    Do you know how deep the hole is for the HU?
    Nov 2006
    Snellville, GA
    Deep enough for my touchscreen and entanglement of wires. Maybe I can measure someday.
    2003 Nissan Xterra Worklog
    Total amount spent so far: $1196.64
    You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
    2003 Nissan Xterra - Modifications
  1. anyone need carputer install or fabrication?
    By damixt in forum Fabrication
    Last Post: 09-29-2005, 12:32 PM
  2. Will pay $$ for simple fabrication.
    By justintime in forum Fabrication
    Last Post: 09-23-2005, 03:38 AM
  3. Need to hire a fabrication expert
    By vladilen in forum Fabrication
    Last Post: 06-16-2005, 12:29 PM
  4. Custom Fabrication Work?
    By mattdisaster in forum Fabrication
    Last Post: 02-01-2005, 11:37 AM
  5. First time fabrication
    By Bellfazar in forum Fabrication
    Last Post: 07-15-2004, 09:56 PM
