does anyone have any pics of a fiberglass box with 4 subs?
and if so how do you get the material you use to cover the skeleton, to cover all the rings and conform to the shape you want? in other words to they all have to portrude to a certain piont where the material contacts every ring?
im asking beacuse i want to tilt my top speaker rings in oppisite direction of the bottom and i dont want to find out i messed up after i,ve glued the top two in place.
the image im trying to achieve is the top two subs close to the center facing outward, and the bottom two at the bottom corners of the box tilted slighty upwards and to the rear! i want to make sure i have that little valley in between the top right and bottom left of the left 2 speakers and the top left and bottom right on the right two speakers.
i hope i could explain it well enough to give you a good mental pic of what i what the end product to come out!!
here is where im at right now!!
LinkBack URL
About LinkBacks
