Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Wood case, for Computer.
  1. #21
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I've used wood for almost all my carpc cases. It allowed me to built one quickly and easily to the dimensions I needed. For mositure resistance just paint it or seal it and be done. If it's soaking up mass amounts of moisture/water I think you are going to have other problems.
  2. #22
    Constant Bitrate Road_Dog's Avatar
    Nov 2006
    USA, Oregon
    My old Firebird was a mobile fishtank. Leaky seals in the trunk, doors, and rear window. Maybe it didn't help that the rear floor boards had holes in them also. It was always moist in that car. Plants were growing everwhere. Ah, the bad ole days.
    I was thinking about metal shielding to prevent the computer and sound card from getting interference from the engine. I had that issue again with my '76 Firebird with mobile (battery powered) radios. Damn igintion.
    Suprised I didn't die in that thing.
    However, sounds like lots of folks had good luck with wood. I think it would be better and stronger than metal for the unique shaped places in cars.
    Road_Dog
  3. #23
    Newbie warrenj38's Avatar
    Mar 2007
    Alberta
    Quote Originally Posted by J187 View Post
    Just a tip, if you predrill holes very small, and you get the brass standoffs with the wide threads, you can thread standoffs into the mdf and it will hold strong and true.
    Well that just solved a mounting issue I was deciding on. Maybe a little wood glue or some kind of bonding material on the threads too?
  4. #24
    Registered User
    Dec 2006
    Scarborough, Ontario
    This seems like an old post..but my computer is in MDF box right now..i have no problems with it..its 3/4 inch mdf..connected together using a special wood silcone and nails..its in the form of a box with a hingdged lid...
    its a small mobo..the via m1000 so u can picture how small the case is..just wory about circulation..so what i did was..i drilled a hole small enought for a 2 inch fan..screwd and silconed that near the back of the case from the inside..so thats bringing in the air..and i drilled a couple holes in the front of the case for exhaust..havent had a problem yet..have been using it for 2 months now..and its positioned beside a subwoofer inclosure..2 12 inch..so u can imagine how much shaking that case is going through..theyre is a gap between them which i filled with sponge so that theyre not resting directly on one another..i hope my post helped..good luck let us now..im going to be posting pics of my case and install soon too..
  5. #25
    Registered User
    Dec 2006
    OHHH..i used weatherstripping to seal the top of the lid to the rest of the box...so its a tight squeeze..and put a mesh grille on the fan for large debris..
  1. revamped case internals and power connector
    By Tuckie in forum Show off your project
    Last Post: 09-13-2006, 11:36 AM
  2. Smallest case that can fit a 3.5 HD
    By iselfdevi in forum General Hardware Discussion
    Last Post: 09-08-2006, 01:22 AM
  3. FS: Casetronic C138 Mini-ITX Case, Black 120W
    By rinroe in forum Classified Archive
    Last Post: 08-15-2006, 03:26 PM
  4. Buy Case Or Build Case
    By setite in forum Newbie
    Last Post: 07-19-2006, 07:31 PM
  5. A-Tech 5000 HP Media Center Case
    By Giuliano in forum General Hardware Discussion
    Last Post: 12-30-2004, 11:27 PM
