Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Wood case, for Computer.
    Constant Bitrate xpluis's Avatar
    Sep 2006
    Mexico City
    Hi all...... i have question...... if i mount my computer on wood case is dangerous? or is ok.
    Computer is hot, and wood not is same steel.... i have fear of burn my system.
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    I had the first version of my carpc was in a wood case, a computer will not get hot enough to light wood on fire. I ditched the wood after I got my new system it was just a pain in the *** to work with. Good luck.
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Engine died)
    Work Log v4.5 --> 05 Toyota Tundra DC SR5
    Constant Bitrate MrJamieR's Avatar
    Jan 2007
    Melbourne, VIC
    There are quite a few modded pc's that use timber cases. I'm no expert but I'm guessing that if your CarPC is hot enough to burn wood you may need to consider some additional cooling!!
    Carputer Haiku (thanks Ian Hughes)
    Serious error.
    All shortcuts have disappeared.
    Screen. Mind. Both are blank.
    Nov 2005
    UK
    i have seen a few mdf cases. I wouldnt worry about burning. however wood doesnt transmit heat like metal does (wood is a far better insulator). This means you will have to rely more on fans and air cooling.
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Yeah wood's cool to use. My case/backseat is MDF and 2x6 / 2x8... I do have 3 80mm fans to circulate air through the edge of the case/backseat...
    FLAC J187's Avatar
    Nov 2004
    Boston
    I too used an MDF custom built case for my first. The thing you have to remember is that most of the time, we build these PCs to be as energy efficient as possible. Meaning less heat. Make sure you have adequate ventilation, but I ran a full biostar Micro-ATX, a 7200 WD HDD, an opus 150 and an athlon 2400+ mobile in an MDF box with zero problems for 2 years.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Sep 2006
    Mexico City
    Thanks all! ok this week i build my mdf custon box, my sistem is:
    PIV 2.2Ghz
    Motherboard Dell <------ fast to wake up, and no noisy motherboard
    256RAM
    300Gb Hd
    WinTV PCI TV/Radio Card
    M2ATX
    I think put in my custon wood case 3 fans coolers.
    Wait me for the pics!...... and tanks all for sugestions
    FLAC J187's Avatar
    Nov 2004
    Boston
    Actually, I recently decided that for my current project I will use MDF again. Just a tip, if you predrill holes very small, and you get the brass standoffs with the wide threads, you can thread standoffs into the mdf and it will hold strong and true.
    Please help.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Furniture
    When I was a kid back in the 60's, almost all televisions and stereos were mounted in consoles. These were basically big beautiful pieces of wood furniture with the electronics housed inside. Nothing new about that idea.
    ~Jimmy
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I have found that using a good grounded metal chassis, with your components grounded will work much better than wood. Less engine whine, less failed parts, and increased stability of the system itself. I'm not saying wood will not work, but I am saying that metal, particularly aluminum, will work much better.
  1. revamped case internals and power connector
    By Tuckie in forum Show off your project
    Last Post: 09-13-2006, 11:36 AM
  2. Smallest case that can fit a 3.5 HD
    By iselfdevi in forum General Hardware Discussion
    Last Post: 09-08-2006, 01:22 AM
  3. FS: Casetronic C138 Mini-ITX Case, Black 120W
    By rinroe in forum Classified Archive
    Last Post: 08-15-2006, 03:26 PM
  4. Buy Case Or Build Case
    By setite in forum Newbie
    Last Post: 07-19-2006, 07:31 PM
  5. A-Tech 5000 HP Media Center Case
    By Giuliano in forum General Hardware Discussion
    Last Post: 12-30-2004, 11:27 PM
