Results 1 to 4 of 4
Thread: Various LCD Meters
    Low Bitrate Epon's Avatar
    Oct 2005
    Various LCD Meters
    I don't really know where else to put this, but I'm thinking about fabbing up some kind of frame in my glove box that would display a few LCD readouts of various things (AC Voltage on mono amp outputs, temperature of PC, etc)
    I've found a bunch of distributors online, but they don't just give prices of single units, nor batches. Has anyone done something like this before that can guide me in the right direction and possibly tell me what other hardware I would need to be doing all this? I mean, my multimeter cost all of 15 bucks, I can't imagine this being expensive at all!
    2004 Ford Mustang
    Mar 2006
    Colorado, but Canadian!
    $15 RadioShack multimer is not a good multimeter. Good enough for light measuring though, but not for heavy details.
    But if you just want LCD output, you can get character LCD's from mouser for pretty cheap.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2005
    I'm not looking for realtime accuracy and resolution, I'm looking to effectively see what my output is at a glance and such. I guess what I'm also looking for is the actual hardware that will be running this, the circuit control boards and stuff. Do they come included with the LCD?
    2004 Ford Mustang
    Mar 2006
    Quote Originally Posted by Epon View Post
    The controller boards do not come with the LCD. There are a couple options:
    1) Build the circuit yourself off of a parallel port using the standard hd44780 controller for under $5
    2) Buy a $50 prebuilt USB unit such as: http://www.thinkgeek.com/computing/avcards/7e3e/
  1. FAQ: Using a Laptop LCD as Your Car PC Screen
    By cproaudio in forum The FAQ Emporium
    Last Post: 06-09-2009, 12:03 PM
  2. Lcd grounding issue, can't get rid of flickering
    By diskey in forum LCD/Display
    Last Post: 05-23-2006, 04:16 PM
