Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 48
Thread: New Generic Double Din chassis design
  1. #11
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by blk02si View Post
    The Thermal properties of aluminum are what keep the heat down. If you have ever felt aluminum it stays cooler than the ambient temp. It has very high heat dissipation properties and works to draw heat away from components. Virtually all chipset heat sinks are made from aluminum or a aluminum/copper combo.
    This part is not quite true:
    "If you have ever felt aluminum it stays cooler than the ambient temp."
    It may "feel" cooler, that effect is due to the Aluminum being able to dissipate heat better than the air at the same temp.
    Water has a similar effect.
    Direct measurement of an AL object sitting on a table for some amount of time will show the same temp for the table, AL object and the air in the room.
    But the object and the table may feel like different temperatures.
    AL is certainly an effective heat sink material, which seems the point of the post and very accurate
    TruckinMP3
    Read the FAQ!
  2. #12
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Even very slight movement of air cools aluminum. I swear, I just let this chassis sit for 15 minutes on a bed in 68 degree temps. Feeling this chassis right now its easily 20 degrees cooler than the ambient temp. I should have a few PC heat sensors laying around, I want to hook them up to the chassis and see if this is really true because its kinda errie how it just stays cold, I just set it on my lap so I could type and I could feel the coldness through my pant leg. Here are some pics of a custom build for diosagain that is the first chassis to use the shelf system. This is a custom DIN 1.5 setup. The renders at the top of the post are the DIN 2.0 setup.
    I should also add that this chassis is extremely lightweight, yet extremely rigid due to the fasteners and bends.
    http://home.comcast.net/~joe.shock/pix/din_1.5_1.jpg
    http://home.comcast.net/~joe.shock/pix/din_1.5_2.jpg
    http://home.comcast.net/~joe.shock/pix/din_1.5_3.jpg
  3. #13
    Jun 2002
    Colorado
    Let me know how the temp measurements turn out
    do the same test with the case and a glass of water on the same table.
    Ambient is ambient.... let it sit long enough the air, table, case and glass will all be the same temp.... it is a branch of physics called thermodynamics.
    TruckinMP3
    Read the FAQ!
  4. #14
    Constant Bitrate diosagain's Avatar
    Feb 2007
    New Jersey
    The case looks great! I can't wait to get my hands on it.
  5. #15
    Oct 2006
    i may be interested in one.
    i dont know how much room i'm going to have because i molded my screen to my 03 mustang double din bezelradio bezel.
    does the screen mount to the chassis?
    95 Mustang 5.0
    Custom Case, VIA m10000, 512 MB, 80gig, M2-ATX, Slot Load DVD, 7" LCD Touchscreen
    80% done
  6. #16
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by Dan95five0 View Post
    I am working on a piece of .063" aluminum that is cut to match a 7" touch and LCD and also match up to the mounting holes on the chassis. I believe a lot of trim applications will not be flat however. This is where the aftermarket or custom trim comes into play. I have 15lb HDU (high density urethane) that I can route. That would be perfect for mounting and LCD and conforming to auto interior lines. It already has texture naturally and would look nice painted and would only be supporting the weight of the LCD and touch panel. But yes the best idea would be to have the screen's trim mounted to the chassis using the same bolt pattern.
  7. #17
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Hello, new to these boards!
    I will definitely buy this if you finish them...
    I just have one question:
    Is the center "shelf" removable?
  8. #18
    Jul 2005
    Motorcity
    Blog Entries
    1
    Yes the center shelf is removable. It needs to be for hardware mounting purposes. Here are the latest renders of the adjustable design. You can basically mount the 'L' bracket plate at any angle, top bottom, whatever to suit your vehicle mounting angles. I took my time on these renders, enjoy:
    http://home.comcast.net/~joe.shock/pix/DD_adj_1.jpeg
    http://home.comcast.net/~joe.shock/pix/DD_adj_2.jpeg
    http://home.comcast.net/~joe.shock/pix/DD_adj_3.jpeg
    http://home.comcast.net/~joe.shock/pix/DD_adj_4.jpeg
  9. #19
    Mar 2007
    Do you think I can use this as a "case" to mount a computer into? Without using an LCD. I want to use an 8" lcd, with a custom dash. If this could be a solution to hiding the computer away...it'd be amazing.
  10. #20
    Jul 2005
    Motorcity
    Blog Entries
    1
    Thats what this basically is, a case. Its made for holding all the PCB's of your autoPC together in a grounded, protected, and lightweight enclosure. As long as you mount this chassis behind the LCD you are fine. Just make sure the LCD ribbon wire is long enough. You can extend the backlight wires if necessary.
  1. Replies: 18
    Last Post: 08-28-2009, 05:16 PM
  2. Question on double din
    By jdiazj1 in forum Newbie
    Last Post: 02-08-2006, 03:54 PM
  3. Help...Trying to install 7" TS in double DIN
    By VIP-Y33 in forum LCD/Display
    Last Post: 10-18-2005, 09:23 AM
  4. Face plate ideas for double din box
    By ShinkunoNamida in forum General MP3Car Discussion
    Last Post: 07-19-2002, 09:48 AM
