Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
Thread: New Generic Double Din chassis design
  1. #21
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Cool. Thanks for the info and quick reply.
    My goal is to mount a motorized flip down touch screen in front of the double DIN case. This case is exactly what I have been looking for!
  2. #22
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I've finalized my CNC tooling to cut .063 damn near perfect, no burs at all, just a shiny aluminum edge. I would not be surprised to see the prototype this week. .
  3. #23
    Nov 2006
    if you get this working I *may* be interested.
    Looks really good
  4. #24
    Oct 2006
    how do you mount that in the dash tho? is there a method or just do what you can to mount it in there
    95 Mustang 5.0
    Custom Case, VIA m10000, 512 MB, 80gig, M2-ATX, Slot Load DVD, 7" LCD Touchscreen
    80% done
  5. #25
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    I would imagine you use the brackets that are holding your radio in the car at the moment. Take the brackets off the radio and put them on the double din chassis
    I installed my carpc into my pet Kangaroo, mate.
  6. #26
    Jul 2005
    Motorcity
    Blog Entries
    1
    Look closely at the renders you will see the fully adjustable side brackets. They will be able to handle depth and angle adjustment. You can also, as NiSlo stated, use the OEM brackets to mount the chassis.
  7. #27
    Mar 2007
    Also as an option in the future you could tap holes in the sides to match up with aftermarket radio bolt holes. This way people could use the stock radio brackets for a perfect first time match. no?
    I know in my Toyota a "universal" bracket like you have shown will not work because the mounting points in the car are off set, I may be able to get one screw in on each side but that to me is not an option for something that needs to be stable.
    Otherwise, I love the idea! I am working with the body of an old deck I have for this sole purpose!
    by the way, how deep is this thing front to back?
  8. #28
    Mar 2007
    Socal
    I especially like the fact that you can remove the L-brackets on the side
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  9. #29
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    are these available now?
  10. #30
    Jan 2006
    I know it's been a while since this thread has been active, but I'll post anyway. I might be building a double-din chassis for my 07 Camry. I've pulled the stock headunit and I've seen the frame behind there: it's double-din. It's only the two side frames with mount holes, etc. So I need to fabricate something with the top and bottom frame as well. I plan on fitting my mini-ITX inside the frame and putting the LCD in front of it as well. It will basically be a complete system in the dash (apart from audio amplifier).
    I plan on building it from aluminium due to its thermal properties. I'll be designing it to fit in my car, so it may not be completely generic, but if there is demand and if I have the time/resources, I might try mass producing a generic version. Any takers?
    I'll post here with any updates/progress.
  1. Replies: 18
    Last Post: 08-28-2009, 06:16 PM
  2. Question on double din
    By jdiazj1 in forum Newbie
    Last Post: 02-08-2006, 04:54 PM
  3. Help...Trying to install 7" TS in double DIN
    By VIP-Y33 in forum LCD/Display
    Last Post: 10-18-2005, 10:23 AM
  4. Face plate ideas for double din box
    By ShinkunoNamida in forum General MP3Car Discussion
    Last Post: 07-19-2002, 10:48 AM
