Page 5 of 5 FirstFirst 12345
Results 41 to 48 of 48
Thread: New Generic Double Din chassis design
  1. #41
    Constant Bitrate stealinfool's Avatar
    Dec 2005
    Orlando
    I'd like to see how this stacks up to the WRX kit as far as completeness.. ie, can I bolt this in a double din opening and (with a install kit) and get the same results for $85? or do I need both your double DIN kit and a solution to mount the LCD?
    Personally, I would like to see a monitor housing like the WRX kit but out of plastic, so I could mold it/epoxy/whatever to my double DIN install kit.
  2. #42
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Hey Guys, Thx for the interest, and thank you Rick for the order.
    I am in the process of updating my website, a complete re-write actually, adding pics, links and other helpful information to help you select the right kit. Should be online within the week. Balancing my company, doing work for a few other companies, working on a second degree and keeping my wife happy takes a LOT of energy! Bear with me.
    @tjbrewster - I have vehicle specific chassis kits for the 04 F-150 with and w/o the metra trim kit.
  3. #43
    Oct 2008
    pmed you
  4. #44
    Oct 2006
    Thumbs up
    Blk02si,
    Very interested, all I need is some more specs on the case to pull the trigger and buy one. Can you provide basic dimensions? Also, I'm not sure an F150 mounts the same as a superduty....the radio mount is not bolted to the dash supports it's kinda snapped in the dash bezel..a real PITA to install. If I'm missing something please clear it up for me. A little more info and I buying one.
    TJ
  5. #45
    Jul 2005
    Motorcity
    Blog Entries
    1
    Hey TJ, from the pictures I'm seeing on the net
    This will fit the f-150 perfect.
    Its a metra kit + my $85 chassis
  6. #46
    Jul 2005
    Motorcity
    Blog Entries
    1
    Here are some pics of the generic kit, complete with mounting brackets. This kit requires you drill and tap holes for your specific mounting requirements. (clean install)
  7. #47
    Aug 2009
    New York, NY
    Thanks for the pic. I have some questions so I pm'd you, well at least I think I did, but I don't see a copy in my Sent Messages folder so dunno if it went through. Please let me know if you didn't get it and I'll resend.
    2009 Toyota Camry SE
    Work Log
  8. #48
    Jan 2006
    Very neat and clean looking case with a very customisable mounting arrangement. I'm sure this will wow the car PC community globally. Keep up the good work.
  1. Replies: 18
    Last Post: 08-28-2009, 06:16 PM
  2. Question on double din
    By jdiazj1 in forum Newbie
    Last Post: 02-08-2006, 04:54 PM
  3. Help...Trying to install 7" TS in double DIN
    By VIP-Y33 in forum LCD/Display
    Last Post: 10-18-2005, 10:23 AM
  4. Face plate ideas for double din box
    By ShinkunoNamida in forum General MP3Car Discussion
    Last Post: 07-19-2002, 10:48 AM
