Page 1 of 5 12345 LastLast
Results 1 to 10 of 48
Thread: New Generic Double Din chassis design
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Well with the amount of interest I've received on double din chassis kits, I decided to draw up a generic kit concept. This kit would have the mounting 'ears' built right into the .063" aluminum and hold an ITX mobo, m2-atx (or other power supply) 3.5 or 2.5" harddrive (up to 2) and the LCD controller board. The LCD itself would be mounted into a foam or plastic trim kit. This will keep all components well grounded and provide a thermal heat sink effect. All PCB's would be mounted on standoffs. Is this something there would be interest in if I make a few?
    http://home.comcast.net/~joe.shock/pix/dd_render_1.jpeg
    http://home.comcast.net/~joe.shock/pix/dd_render_3.jpeg
    http://home.comcast.net/~joe.shock/pix/dd_render.jpeg
    http://home.comcast.net/~joe.shock/pix/screencap.jpg
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    I'm using the WRX kit and am going for a full indash setup, but if that weren't around I'd be straight onto something like that.
    Infact, after seeing that seconnd tier you have put in above the mobo, I'm thinking that might be the way to go for to mount my HDD and m2-atx.
    Have you had any issue with heat? Just on the bench my whole chassis is getting quite hot, but no more than the stock headunit does at the moment in the car. That second 'level' might help me mount a fan in the somewhere to help with the heat.
    I reckon quite a few people would be keen on that as few people have the knowledge and resources to do it themselves. Even if they don't go for a full indash setup like you and I, they will still have a nice solid chassis to mount their screen on and anythign else that doesn't need easy access (PSU/SDC/HDD).
    Would you pre-drill the holes for the most common components? (the WRX kit has the holes pre-dilled to mount the M10k and any other mobos with the same mounting points)
    I installed my carpc into my pet Kangaroo, mate.
    Mar 2007
    How much you think this would go for? My only concern really is heat. I understand how heatsinks and all work, but how would this act like one? I think it's a good idea if you don't want to worry about fabricating your own case, and want to keep things organized!
    Jul 2004
    Would it be possible to have adjustable ears instead of fixed ones? I have an 05 Focus and the mounting locations are about 2 1/2" deeper than the Mustang.
    Jul 2005
    Motorcity
    Blog Entries
    1
    This would probably go for around 80 USD. The holes for the mobo would be machined in place (mini ITX form factor) Also I can make the ears adjustable which is probably a good idea for a generic case. Make them slide so the actual chassis depth can be adjusted. Ill post up some more renders when I get home
    Mar 2006
    Colorado, but Canadian!
    For $80, you got a sale!
    1.9in x 2.9in -- 47mm x 73mm
    Jul 2005
    Motorcity
    Blog Entries
    1
    The Thermal properties of aluminum are what keep the heat down. If you have ever felt aluminum it stays cooler than the ambient temp. It has very high heat dissipation properties and works to draw heat away from components. Virtually all chipset heat sinks are made from aluminum or a aluminum/copper combo.
    Constant Bitrate diosagain's Avatar
    Feb 2007
    New Jersey
    Joe, you are one smart guy. I think you could sell a ton of these.
    Mar 2007
    I have been thinking about putting a PC in my car for a while and I would DEFINITLY be interested in this. Would this bracket be able to hold the xenarc 700TS LCD screen with out taking apart the LCD?
    http://www.xenarc.com/product/700ts.html
    Mar 2007
    Quote Originally Posted by blk02si View Post
    Thanks for the explanation. But doesn't the metal have to actually be touching the components to function? Sorry, I'm new to the whole getting rid of heat thing.
    Even though, I can't wait to order this baby!
  1. Replies: 18
    Last Post: 08-28-2009, 06:16 PM
  2. Question on double din
    By jdiazj1 in forum Newbie
    Last Post: 02-08-2006, 04:54 PM
  3. Help...Trying to install 7" TS in double DIN
    By VIP-Y33 in forum LCD/Display
    Last Post: 10-18-2005, 10:23 AM
  4. Face plate ideas for double din box
    By ShinkunoNamida in forum General MP3Car Discussion
    Last Post: 07-19-2002, 10:48 AM
