there is probably a local plastics supply outlet near you... but in the event you can't find one:
Many plastics can be obtained here.
The plastic sheets come in a few thicknesses, and have a haircell finish on one side. This is kind of similar to the faux leather texture sometimes stamped on vinyl for upholstery etc... If that's an issue then you can use the flip side which is smooth. I'd also look at picking up a plastic welder and some ABS welding rods. I can just about guarantee that there will be a joint that really needs gap-filling or shaping and the last thing in the world you're going to want to do is use bondo to try and smooth it out. Bondo = Problems.
It's a good idea to make your part as much out of a single material as you can. This allows it not only to bond perfectly, but it lets it expand and contract at the same rate which is critical to maintaining a painted surface or preventing cracks.
