Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: 89 Toyota Supra Fab Round 2
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Well, it's time to redo my Supra screen. I purchased a 2nd hand screen (7" Super/Avatar) from a fellow member and a Metra Ford kits (95-5812) as done by blk02si in this thread. The purpose was to use the Metra kits to build a frame for the LCD bezel to attach instead of fab the LCD bezel directly to the radio bezel. Why you ask? Well, if the LCD crap out on my down the road, I'll just take the lcd bezel out and glue a new on (if different brand) on to the metra frame. This approach will save me from doing another fab job whenever I replace a new screen. The radio bezel is a abs plastic cover with rubber. This combination of material make it really difficult to fab.
    Anyway, this is the original fab job on a modded 5" PSOne screen.. I want to re-use the radio bezel although I had in my hand 2 extra bezels from junkyard. I have to remove the old paint and the PSOne screen out.
    I ask the forum regarding to paint stripping. Most was suggest to use sanding method
    As you can see in the picture below, the paint is pelling off.
    A closer look.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Sep 2003
    Beach City, Socal
    Thanks to my crappy fab job I did 2.5 years ago, I was able to peel the paint off without any sanding. within 2 hrs.
    Next was to prepare the frame and the LCD bezel. The frame is the Metra Late model Ford Kit 95-5812 which is the same as the kit the double DIN in kit (99-5807) that blk02si used in his install.
    The bezel sure pop right into the kit openning if you trim the bottom of the bezel.
    Well not exactly perfect fit. There is a gap in front of the bezel because the bezel is wider.
    I have to either trim the 2 sides of the bezel or modify the side metra kit. I opt to trim the 2 side of the bezel and it pop right in. Perfect .
    Sep 2003
    Beach City, Socal
    I have to trim the radio bezel a little wider to fit the Metra kit in the openning.
    Just to double check that there is at least 1 DIN high or room for the Alpine HU.
    More test before epoxy. You can see I use balsa wood to fill/jam the gap between the radio bezel and the metra kit.
    Epoxy is in.
    The back side.
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Nice, got tired of the psone screen?
    Sep 2003
    Beach City, Socal
    Actually, I like the PSOne and still do. Really bright for my semi convertible usage. I replace it because I the fab start to get crappy and I can get the 7" for cheap. I just wait and see how is this 7" serve me. Otherwise, I will go transflective .
    Okay more to the fab.
    After the epoxy was cured, I try to fit the LCD bezel again. I was shock because the metra is twisted a little and no longer a perfect rectangle. It was due to the stretch/squeze when I put those balsa wood.
    Also I should of cutting up a piece of wood/board to fit into the kit to keep the it from bending out of shape.
    I end up using the solution below to push it out a little and test how good the epoxy really bond the pieces.
    Rub around the epoxy part with a 60 grid sand paper and ready for the filling. I already has some SEM bumper repair left over from the Matrix job and use that. I should of try the 3M that TurboCad6 used. So far SEM is good enough base on the matrix job because the bezels are just abs plastic. The supra material is a totally different one. Rubber
    Sep 2003
    Beach City, Socal
    This is the first couple layers of SEM bumper repair.
    I put a thin layer at a time. Thin layer give it an option to cure faster then 1 thick layer.
    This one is after first 150 grid sand. Before that was about 3 passes of 60 grid sand paper. I just applied more filler to build it up after each sand.
    So far looking good
    Mar 2006
    Colorado, but Canadian!
    looks good so far!
    1.9in x 2.9in -- 47mm x 73mm
    Sep 2003
    Beach City, Socal
    Here are a few more pics.
    Prime, wetsand, glaze putty, prime, wetsand .... about 3 times.
    I'm getting tired of sanding and stared to do the whole thing. I thought cuz the original piece isn't perfect, why should I spend too much time make this this portion perfect
    The last 2 pics are one with first coat of paint. I use flexible vinyl paint. It isn't sandable paint. So far, it isn't dry evenly, and was taken 5 minutes after spraying.
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    Looks way better than what you had before, Awesome job!!!
    FLAC J187's Avatar
    Nov 2004
    Boston
    Exteme makeover Matix PC style. Looks infintely better. Nice. Can't wait to see it fully done.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  1. 91 Toyota Supra Fabrication
    By dsballer2000 in forum Fabrication
    Last Post: 06-06-2009, 09:18 PM
  2. 1998 Toyota Supra RZ-s Install
    By jazz13 in forum Show off your project
    Last Post: 04-22-2007, 07:01 PM
  3. 89 Supra Turbo finished (for now)
    By drait in forum Show off your project
    Last Post: 04-16-2007, 12:38 PM
  4. WANTED - Toyota Supra 1990 Roof bars
    By tracysupra in forum Classified Archive
    Last Post: 11-01-2005, 07:22 PM
  5. Toyota Supra TT mkiv
    By spyda in forum Show off your project
    Last Post: 02-21-2005, 06:08 PM
