Results 1 to 10 of 16
Thread: LCD Install Help for '04 Grand Prix
    Mar 2007
    Question LCD Install Help for '04 Grand Prix
    Hey guys. This is my first post and I am all ready to get my carputer all setup. I have all the parts - just need to know where to mount the LCD. Where can I mount the LCD (8.4" VM84) and still keep the radio & info display? I wouldn't mind moving stuff around, but I don't know where to mount it. What do you guys suggest? I've attached a picture to get an idea what I am looking at. The only idea i've thought of is having it stick up from the top of the dash bezel, but i'm worried about sunlight and such.
    Thanks in advance.
    Troy
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    I'd start by moving your HVAC controls and the pocket below it to another location. When you're driving, the shift lever will be well out of the way. If in fact that dash opening is wide enough, then i'd go ahead and angle the screen back in there and adjust it to what looks right to you while you're in the drivers seat. Once you've got it in place, then make the PERFECT bezel or the NOT AS PERFECT AS THE PERFECT BEZEL BUT PERFECT IN A DIFFERENT SORT OF WAY THAT IS GOOD ENOUGH FOR SOME PEOPLE bezel.
    Any questions, feel free to ask.
    welcome to the life!
    hac
    hac is offline
    Aug 2006
    what he said up there. theres a lot of potential in that dash of yours for relocating stuffs. personally id move the hvac down but snip the 3 little buttons to the side or somewhere else so i can "squeeze" in more space. then follow with the radio and finally the lcd on top. if your worried about the sunlightand glare you can make the enclosure recessed as in here How-To: Recessed Screen and DVD Drive
    goodluck bro!
    Mar 2006
    Colorado, but Canadian!
    First I would get rid of the pocket. Then I would put the radio where the pocket is. Then the 3 knobs and 3 small buttons should fit on the horizontal surface where the shifter is, or maybe up top somewhere, but basically elsewhere.
    Then the screen would go up top. I think the shifter would get sorta annoying but that could just be the way I tap my screen. That and looking so far down could be sub-optimal when flying down the interstate.
    1.9in x 2.9in -- 47mm x 73mm
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    Personally, get rid of pocket, move both the hvac and radio down one position, so the radio is where the hvac was, and the hvac is where the pocket was, then put the screen where the radio was...
    A little extra work, but It'll be worth it in that your screen will be higher up, making it use able, and viewable as your are driving...
    Nothing is worse then having to look straight down when driving...
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    FLAC J187's Avatar
    Nov 2004
    Boston
    You could get crazy Esse??
    Or, the HVAC controls would go nicely in those pockets along the shifter.
    @Dennis - The screen wouldn't fit. He'd need the HU area + the pocket, leaving the HVAC w/ no home./
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Mar 2007
    Thanks for the feedback - those are some good ideas.
    I'm not very good with photoshop but after measuring this is what I've come up with so far(if someone is better with photoshop and wants to help me out I would appreciate it
    Let me know what you think - I want to put the HVAC controls infront of the shifter, move the radio down, get rid of the cubby hole, and put the LCD as high as possible for the backseat passengers.
    I also have a sirius satellite radio that is mounted above the info lcd right now that I may incorporate into this as well - not sure - it measures 5"x2".
    I am going to purchase the block of insulation to get my mold for this thing this weekend hopefully. Then the fun begins
    Jun 2006
    Denver, CO
    oh that's gonna be fun
    something tells me those HVAC controls are going to have to go somewhere else....
    I'm assuming they're all electronic, i.e. no cable pulls. If that's the case, have you considered looking at different types of switches/knobs you can use to make the relocation work a little better? If you find a switch with the right values or can build one, then it's really just a matter of extending wires... that should give you more flexibility in placement.
    FLAC J187's Avatar
    Nov 2004
    Boston
    Dude, having driven that car for a while and owning an 8" screen, off the top of my head, I'd say you might not even fit the two things there, let alone all three.
    I am pretty good at photoshop, but I hacked that together thinking what is the point of making look really nice. I think your quick and easy photoshop gets the point across fine, I just don't think it will fit
    Please help.
    Oct 2006
    Forget about keeping the stock radio. I'd hate to say it but it's honesly the only option you have without tons of fab work.
    Run the computer straight to a 2ch amp, and run the amp to your speakers. You'll have all the room you need.
  1. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 12:20 AM
  2. Which type of LCD to install on Fiat Doblo?
    By kwchan in forum Fabrication
    Last Post: 12-12-2006, 03:04 PM
  3. Audi A4 install - LCD finally customed into dash
    By brrman in forum Show off your project
    Last Post: 10-07-2003, 10:47 AM
  4. Preview of my in Dash LCD install
    By Destin in forum General MP3Car Discussion
    Last Post: 01-27-2001, 10:48 AM
