Results 1 to 7 of 7
Thread: PC Positioning!
    Mar 2007
    PC Positioning!
    I have a peugeot 206 and want to know where the best place to put a VoomPC 2 enclosure is???
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    Where ever you like, under the driver seat?
    Be creative
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Mar 2007
    ive tried that, doesnt fit. ive obviously tried the normal sort of places, but i dont want to cut away too much of the car!!
    Variable Bitrate tigergibb's Avatar
    Nov 2006
    Snellville, GA
    Under the passenger seat? My passenger seat has more space than my driver seat underneath. You could also try the trunk, the glovebox, or the console.
    2003 Nissan Xterra Worklog
    Total amount spent so far: $1196.64
    You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
    2003 Nissan Xterra - Modifications
    Constant Bitrate symon_say's Avatar
    Aug 2006
    Dominican Republic
    trunk
    Constant Bitrate MrJamieR's Avatar
    Jan 2007
    Melbourne, VIC
    If it doesn't fit under the seats, you don't want to cut the car up (so behind the dash is out) and as your car is tiny, then the trunk (or under the hatch) is the only place left isn't it?
    Carputer Haiku (thanks Ian Hughes)
    Serious error.
    All shortcuts have disappeared.
    Screen. Mind. Both are blank.
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    This is my setup:
    The m2 atx, mb (mini itx) and hdd (2,5 inches), silabs fm radio, dvb-t receiver, odb2 interface are located in the rear of the monitor (a 16:9 7" monitor); gps antenna is inside the left rear-mirror, dvd player/burner is on the top of the central dome, the amplifier is located in the trunk together with a 6" amplified bazooka :-P
    I have no wasted space in my car, no wires in the way, nothing under the seats, no cut of original parts because the central console and dome are copies (customized) of the original ones... Moreover I haven't lost my central air vents because I rebuilt these (a reduced version!) on the modified central console...
    For my experience, this is the best setup applicable for this car if you want a car-pc because of simplicity in connections and accessibility of monitor. I tried a 7" monitor under the central dome (a oversized rebuilt version) but this was hard to reach while driving! It was really uncomfortable.
  1. PC audio too low
    By Alphared in forum General Hardware Discussion
    Last Post: 10-04-2008, 05:20 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  3. FS: CarPC 2.4 startup/shutdown controller
    By evilragu in forum Classified Archive
    Last Post: 03-05-2006, 05:28 PM
  4. first car pc project
    By machineshop in forum Newbie
    Last Post: 12-15-2005, 04:17 PM
  5. basic car pc idea
    By Joseph in forum Newbie
    Last Post: 11-08-2004, 03:04 PM
