Results 1 to 7 of 7
Thread: 03 Vibe GT install. Yet another.
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    After looking at other Vibe/Matrix owner installs on here, I'm finally going to start mine.
    I picked up a new bezel at the dealer. $35. Looked on eBay and they wanted more than that for a used one. LOL So, I'm using the new on in the car until I fab up my original.
    The monitor is a VM7200. I trimmed the bottom of the bezel off with a saw, then used a dremel to cut the top. Then welded them together with Perma Poxy plastic weld.
    Heres the begining... As soon as I find the bumper repair stuff, I'll move on.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
    Mar 2006
    Pennsylvania
    This is the only bumper repair stuff I could find anywhere locally. I'm assuming it will work, since it says it's for ABS plastic and is flexible.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
    Feb 2007
    Good luck! Always good to see a fellow matrix/vibe owner heading this route! Here is my screen.. just have to finish up a few minor gaps and then paint it! Bezel
    Mar 2006
    Pennsylvania
    Used the bumper repair and sanded it all down. Now I need to fill in the tiny air bubble craters. Is the best way to do this to fill them with tiny drops of the bumper repair? I really cant sand them out anymore without messing it up.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Did you epoxy/glue the lcd frame to the radio bezel before applying bumper repair? You should because bumper repair isn't mean to be use as adhensive. It will stick for now, but eventually will break apart as it isn't strong enough to hold the piece together.
    As for filling the tiny air bubbles or pin hole, I use glazing and spot putty.
    You can use this as they are the same with just smaller size.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Mar 2006
    Pennsylvania
    Ah, ok. I read that in your supra thread and wondered.
    As for attaching the LCD frame, yep. I used Perma Poxy plastic weld. Dont think it's coming out anytime soon. I even used it to fix the stand on my fan. Strong stuff! lol
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
    Mar 2006
    Pennsylvania
    This blows! After doing the bezel, I reinstalled the screen and turned it on. Came on for like 2 min. then went out. So, I unplugged it, opened it up and it started working. Put it back together, was running fine. Then I unplugged it for a second and when I plugged it back in, nothing. Now it just sits there.....blank...in a bezel. I have NO idea whats wrong with it. Tested the PS and it's fine.
    Any ideas anyone?
    Update
    Got the screen working. For some reason, one of the power wires was soldered in the cable itself, and shrink tube put on it. It broke loose.
    Now, my computer refuses to reconize the monitor! It says 'USB Device Not Reconized'. Just installed the new drivers three times and nothing. Anyone else have this trouble?
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  1. 03 WRX Wagon Install
    By sxott in forum Show off your project
    Last Post: 08-13-2007, 06:03 PM
  2. Replies: 10
    Last Post: 11-20-2006, 06:14 PM
  3. XP install hold on install because of space
    By sammie1303 in forum WinNT Based
    Last Post: 11-16-2006, 12:09 PM
  4. Subaru Legacy GT Limited Install Complete
    By xcntrk75 in forum Show off your project
    Last Post: 03-09-2006, 02:32 PM
  5. 99 GP GT Install
    By looneeii in forum Fabrication
    Last Post: 07-11-2005, 10:57 AM
