Results 1 to 10 of 14
Thread: First Fab job. Where to go from here?
    Dec 1999
    OK I had my first chance to play with bondo-glass tonight. It was much harder to work with than I thought it would be. I thought it would be more pasty than chunky.
    Since I now have a fairly good base with bondo-glass. Could I switch to something a little easier to work with for the final layers?
    ScAndal
    Mar 2006
    Colorado, but Canadian!
    You still have huge chunks missing for some reason. Use the fiberglass bondo to get those filled in. Then for the little holes, and final shaping you can use regular bondo. For rough shaping, use what you have been.
    1.9in x 2.9in -- 47mm x 73mm
    Dec 1999
    Thanks for the feedback. What tool do you recommend using when applying the bondo-glass? I was just using a wood block and maybe thats my problem?
    ScAndal
    Mar 2006
    use gloves and then your hand. Your finger is the best tool.
    Dec 1999
    Ah I didn't even think about that
    That would be so much easier.
    Thanks for the tips. I'll post how round 2 goes tomorrow.
    ScAndal
    FLAC J187's Avatar
    Nov 2004
    Boston
    FIrst off, those holes are too big to just fill in with the stuff you are using, which I dont' think is BondoGlass.... You need to sand down those craters until they are smaller so they become shallower.
    Why do you think the product you are using is bondoglass? Does it say bondoglass, or are you just assuming that because it is fiberglass reinforced bondo that it is bondoglass? The reason I ask is because it doesn't look like from the picture that that stuff is bondo glass. It looks like kitty's hair or tiger's hair. Much harder to manipulate than bondoglass. The difference? Bondoglass(which is just a brand name like Kleenex is) refers to a bodyfiller/SHORT strand fiberglass mixture. Kitty's hair or tiger's hair or other brands refers to a bodyfiller/LONG hair fiberglass mixture.
    Often when I fabricate something, I use both. I lay my base of kitty's hair, then I sand down flat and smooth, do my major shaping with the major strength product. Then I go back and fill and build up with Bondoglass. Then I move on to a lightweight body filler like Litebondo to fill in the dimples and provide some fine tune shaping. Then a nice glazing putty to smooth it all out. Always sanding between. I knock down my first coat of kittys hair using first a DA sander and then 36 grit handpaper. Then I go to 60 grit. After the coat of Bondoglass I go to 80 grit and then 100 grit. I move on to 150 after the litecoat and so on. All the way up to 500 grit.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Oct 2006
    Quote Originally Posted by 2k1Toaster View Post
    that's what she said!
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I would suggest you dump those bondo you have in your garage and buy the 3M Automix or SEM flexible bumper repair which can be use as filler. Easier to sand and work with. I use a piece of plastic to apply and spread filler material.
    The Dynatron you see in the picture above use as adhensive re-enforce the pieces.
    check this thread
    http://www.mp3car.com/vbulletin/fabr...ory-bezel.html
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    FLAC J187's Avatar
    Nov 2004
    Boston
    Um, I wouldn't be so quick to admit that Spoon, If thats what she said, it says something about the other tools in the garage, no?
    OP - can you verify if the material you are using is short strand or long.
    @ Matrix, by now, the bezel is already mostly encapselated in bondoglass or whatever it is. There is no reason not to continue this way. I have used many abs plastic and plastic repair materials, including those shown above. They work quite well, but Are not superior to bondo glass necessarily for all projects. They offer more flex and that is good in some regards, but not in some cases. I think it would be a little easier to finish this project with the materials it was started with. This time at least.
    Please help.
    Aug 2005
    Pennsylvania
    Using a putty/bondo spreader that you can buy at any auto parts store is better and easier than using your fingers to spread the bondo. Also sanding when the bondo is drying at a certain phase that it goes through that makes it fell like clay is the easiest and fastest way to sand things down smoother.
  1. What is the worst job you ever had?
    By fluffy2097 in forum Off Topic
    Last Post: 04-22-2008, 02:55 PM
  2. 89 Toyota Supra Fab Round 2
    By MatrixPC in forum Fabrication
    Last Post: 04-24-2007, 12:58 PM
  3. deleted
    By phc in forum General MP3Car Discussion
    Last Post: 01-13-2006, 03:10 PM
  4. '93 Jeep Grand Cherokee In-Dash LCD Fab Questions
    By J-Hood in forum Fabrication
    Last Post: 11-24-2005, 11:54 PM
  5. 05 honda accord coupe fab finished - customer job
    By xdjxklusivex in forum Fabrication
    Last Post: 06-21-2005, 09:59 PM
