Page 12 of 20 FirstFirst ... 234567891011121314151617181920 LastLast
Results 111 to 120 of 197
Thread: Tutorial - Steering Wheel Controls
  1. #111
    Mar 2008
    I think you should try what 2k1 is asking lol.. Not sure how to create a virtual brain but if anyone can help, it would be him.
  2. #112
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    I looked at your video, followed every step of the way
  3. #113
    Mar 2006
    Colorado, but Canadian!
    Virtual Brain will show every input and output.
    Maybe you measure X volts in, but depending on how you hooked it up, maybe it isnt reading X Volts, but Y volts. A virtual (not visual) brain will show you what the program is seeing. It will show everything. Then you can use the if/then window to see what is evaluating to true, and what is evaluating to false.
    To add debug options, use the configurator and click the debug icon (the little bug on the right side). Check the global enable item. Then select what windows you want to show when debugging is enabled. Save and open MDX.
    1.9in x 2.9in -- 47mm x 73mm
  4. #114
    Oct 2005
    so when Im doing making my own config file, I just replace it with the one in mdx file? before when I did that I get a error ''configuator file not found" , then it say unknown error in configuator file. Then it a white screen.
  5. #115
    Mar 2006
    Quote Originally Posted by customaudioman View Post
    Save it directly to the MDX directory. Just copying the file wont do since all images, text, functions, and other dependencies need to be copied to. Easiest for you is just save directly to the MDX directory.
  6. #116
    Oct 2005
    so I shoundnt edit the mdx configuator file configurator ? I should start my own like in the video?
  7. #117
    Oct 2005
    Quote Originally Posted by 2k1Toaster View Post
    save it in MDX program file? another place? whats the directory?
  8. #118
    Mar 2006
    Directory: A folder that is an entity in a file system which contains a group of files and/or other directories.
    File: A set of related information that a computer can access by a unique name
    When the configurator saves the configuration, it save an XML file, along with a content directory that contains other directories and files such as images and fonts. Copy the XML file and not the content directory, you didnt complete the copy, things wont work.
    "MDX Program File" is Fusion Control Centre UberMDX.exe
    You can save over that file if you really want to, but then you dont have a program any more and nothing will work.
    MDX's directory is the entity that contains Fusion Control Centre UberMDX.exe directly (not within another directory). You could have it saved in the default location "C:\Program Files\Fusion Control Centre Uber MDX Edition\MDX" or you can save it to F:\Fluffy Bunny\ it doesnt matter as long as it is where you installed the program to.
    If your program installed to F:\Fluffy Bunny\ and you save your configuration file to Z:\Doom, then how will the program in Fluffy Bunny know to look in one of a billion directories on your computer, the internet, your network, your flash drives, everything to find that one specific file on Z:\Doom???. Common sense dictates it will not search the universe for 1 file, it will instead read what it can from the Fluffy Bunny directory.
    So save whereever you like, but to get it to work, you better save it where the program is installed to.
  9. #119
    Mar 2005
    Honesty, and i want you to think carefully before you answer this, did you do EXACTLY what 2k1 posted in his video? We're getting frustrated here - your messages are vague and conflicting. Several dozens of users have managed to do what you are trying to do, with nothing but what we've provided so far. In a last ditch attempt to help, please follow these steps CAREFULLY.
    Navigate to: C:\Program Files\Fusion Control Centre Uber MDX Edition\MDX
    Right click "FusionConfiguration.xml"
    Select Edit from the menu.
    Delete everthing in the notepad window.
    Copy/paste the following code into the notepad window:
    Code:
    <?xml version="1.0" encoding="utf-8" ?>
    <FusionControlCentreConfiguration version="3.0" author="Ninja Kitty Wizard of Doom" date_created="Wednesday, October 01, 2008 at 10:04:18 PM" last_modified="Wednesday, November 12, 2008 at 5:41:34 PM">
      <require>
      <!-- Begin Function Instances -->
      <!-- End Function Instances -->
      <!-- Begin Fusion Font Instances -->
          <font name="Verdana" originalSize="25" font_config="content\fonts\Verdana.xml"></font>
      <!-- End Fusion Font Instances -->
      </require>
      <speech enabled="false" global_politeness="true">
      <!-- Begin System Speech Instances -->
      <!-- End System Speech Instances -->
      <!-- Begin System Speech Definition Instances -->
          <system_definitions>
          </system_definitions>
      <!-- End System Speech Definition Instances -->
      <!-- Begin Custom Speech Definition Instances -->
          <custom_definitions>
          </custom_definitions>
      <!-- End Custom Speech Definition Instances -->
      <!-- Begin Custom Query Instances -->
          <custom_queries>
          </custom_queries>
      <!-- End Custom Query Instances -->
      </speech>
      <general>
      <!-- Begin Debug Instances -->
        <debug status="on">
          <window type="variables"></window>
          <virtual_brain id="my fusion brain 0"></virtual_brain>
        </debug>
      <!-- End Debug Instances -->
      <!-- Begin Remote Control Configuration -->
        <remote status="disabled" user_name="default" port="4242"></remote>
      <!-- End Remote Control Configuration -->
      </general>
      <graphics>
      <!-- Begin Global Graphic Settings -->
          <main_display designed_for_size="800,600" show_at_size="800,600" menubar="Sizeable" RunInSystemTray="False" MinimizeToSystemTray="True"></main_display>
      <!-- End Global Graphic Settings -->
      <!-- Begin Background Images -->
          <background_image style="stretch" imagefilepath="content\images\background_images\background.jpg" page="0"></background_image>
          <background_image style="stretch" imagefilepath="content\images\background_images\background.jpg" page="1"></background_image>
          <background_image style="stretch" imagefilepath="content\images\background_images\background.jpg" page="2"></background_image>
      <!-- End Background Images -->
      <!-- Begin Static Images -->
          <staticimage>
            <image path="content\images\static_images\button_larger.png"></image>
            <display size="355,70" location="37,219" page="1" z_order="0.9"></display>
          </staticimage>
          <staticimage>
            <display size="355,70" location="412,219" page="1" z_order="0.9"></display>
          </staticimage>
          <staticimage>
            <display size="355,70" location="37,319" page="1" z_order="0.9"></display>
          </staticimage>
          <staticimage>
            <display size="355,70" location="412,319" page="1" z_order="0.9"></display>
          </staticimage>
          <staticimage>
            <display size="355,70" location="37,119" page="2" z_order="0.9"></display>
          </staticimage>
          <staticimage>
            <display size="355,70" location="412,119" page="2" z_order="0.9"></display>
          </staticimage>
          <staticimage>
            <display size="355,70" location="37,219" page="2" z_order="0.9"></display>
          </staticimage>
          <staticimage>
            <display size="355,70" location="412,219" page="2" z_order="0.9"></display>
          </staticimage>
          <staticimage>
            <display size="355,70" location="37,319" page="2" z_order="0.9"></display>
          </staticimage>
          <staticimage>
            <display size="355,70" location="412,319" page="2" z_order="0.9"></display>
          </staticimage>
          <staticimage>
            <image path="content\images\static_images\logo.png"></image>
            <display size="556,27" location="123,44" page="0" z_order="0.9"></display>
            <multiple_pages page="1"></multiple_pages>
            <multiple_pages page="2"></multiple_pages>
          </staticimage>
      <!-- End Static Images -->
      <!-- Begin Variable Location Images -->
      <!-- End Variable Location Images -->
      <!-- Begin Graph Instances -->
      <!-- End Graph Instances -->
      <!-- Begin Display Buttons -->
          <button id="NINJABUTTON_Digital_Output_0" enabled="yes" function="trigger output" functionTargetID="digital output 0" vote="attached" vote_opinion="on" vote_priority="Medium">
            <images imagePrimary="content\images\button_images\button_down.png" imageSecondary="content\images\button_images\button.png" imageDisabled="content\images\button_images\button.png" imagePushed="content\images\button_images\button_down.png"></images>
            <display size="230,70" location="37,119" page="0" z_order="0.9"></display>
            <vote_options minimum_delta_vote_time_down="20" ></vote_options>
            <text font="verdana" font_size="25"></text>
            <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 0"></text>
            <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 0"></text>
          </button>
          <button id="NINJABUTTON_Digital_Output_1" enabled="yes" function="trigger output" functionTargetID="digital output 1" vote="attached" vote_opinion="on" vote_priority="Medium">
            <display size="230,70" location="287,119" page="0" z_order="0.9"></display>
            <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 1"></text>
            <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 1"></text>
          </button>
          <button id="NINJABUTTON_Digital_Output_2" enabled="yes" function="trigger output" functionTargetID="digital output 2" vote="attached" vote_opinion="on" vote_priority="Medium">
            <display size="230,70" location="537,119" page="0" z_order="0.9"></display>
            <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 2"></text>
            <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 2"></text>
          </button>
          <button id="NINJABUTTON_Digital_Output_3" enabled="yes" function="trigger output" functionTargetID="digital output 3" vote="attached" vote_opinion="on" vote_priority="Medium">
            <display size="230,70" location="37,219" page="0" z_order="0.9"></display>
            <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 3"></text>
            <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 3"></text>
          </button>
          <button id="NINJABUTTON_Digital_Output_4" enabled="yes" function="trigger output" functionTargetID="digital output 4" vote="attached" vote_opinion="on" vote_priority="Medium">
            <display size="230,70" location="287,219" page="0" z_order="0.9"></display>
            <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 4"></text>
            <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 4"></text>
          </button>
          <button id="NINJABUTTON_Digital_Output_5" enabled="yes" function="trigger output" functionTargetID="digital output 5" vote="attached" vote_opinion="on" vote_priority="Medium">
            <display size="230,70" location="537,219" page="0" z_order="0.9"></display>
            <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 5"></text>
            <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 5"></text>
          </button>
          <button id="NINJABUTTON_Digital_Output_6" enabled="yes" function="trigger output" functionTargetID="digital output 6" vote="attached" vote_opinion="on" vote_priority="Medium">
            <display size="230,70" location="37,319" page="0" z_order="0.9"></display>
            <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 6"></text>
            <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 6"></text>
          </button>
          <button id="NINJABUTTON_Digital_Output_7" enabled="yes" function="trigger output" functionTargetID="digital output 7" vote="attached" vote_opinion="on" vote_priority="Medium">
            <display size="230,70" location="287,319" page="0" z_order="0.9"></display>
            <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 7"></text>
            <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 7"></text>
          </button>
          <button id="NINJABUTTON_Digital_Output_8" enabled="yes" function="trigger output" functionTargetID="digital output 8" vote="attached" vote_opinion="on" vote_priority="Medium">
            <display size="230,70" location="537,319" page="0" z_order="0.9"></display>
            <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 8"></text>
            <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 8"></text>
          </button>
          <button id="NINJABUTTON_Digital_Output_9" enabled="yes" function="trigger output" functionTargetID="digital output 9" vote="attached" vote_opinion="on" vote_priority="Medium">
            <display size="230,70" location="37,119" page="1" z_order="0.9"></display>
            <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 9"></text>
            <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 9"></text>
          </button>
          <button id="NINJABUTTON_Digital_Output_10" enabled="yes" function="trigger output" functionTargetID="digital output 10" vote="attached" vote_opinion="on" vote_priority="Medium">
            <display size="230,70" location="287,119" page="1" z_order="0.9"></display>
            <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 10"></text>
            <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 10"></text>
          </button>
          <button id="NINJABUTTON_Digital_Output_11" enabled="yes" function="trigger output" functionTargetID="digital output 11" vote="attached" vote_opinion="on" vote_priority="Medium">
            <display size="230,70" location="537,119" page="1" z_order="0.9"></display>
            <text colourPrimaryARGB="255,255,255,255" textPrimary="Digital Output 11"></text>
            <text colourSecondaryARGB="255,255,255,255" textSecondary="Digital Output 11"></text>
          </button>
          <button id="Button_ChangePage_Next" enabled="yes" function="change page" functionTargetID="required filler" vote="attached" vote_opinion="+1" vote_priority="Medium">
            <images imagePrimary="content\images\button_images\button_next.png" imageSecondary="content\images\button_images\button_next.png" imageDisabled="content\images\button_images\button_next.png" imagePushed="content\images\button_images\button_next_down.png"></images>
            <display size="115,70" location="652,489" page="0" z_order="0"></display>
          </button>
          <button id="Button_ChangePage_Previous" enabled="yes" function="change page" functionTargetID="required filler" vote="attached" vote_opinion="-1" vote_priority="Medium">
            <images imagePrimary="content\images\button_images\button_previous.png" imageSecondary="content\images\button_images\button_previous.png" imageDisabled="content\images\button_images\button_previous.png" imagePushed="content\images\button_images\button_previous_down.png"></images>
            <display size="115,70" location="37,489" page="0" z_order="0"></display>
          </button>
      <!-- End Display Buttons -->
      <!-- Begin Multi Images -->
      <!-- End Multi Images -->
      <!-- Begin Text Labels -->
          <text_label id="Text_Label_Analogue_Input_0" text="Analogue Input 0: " auto_monitor="variable" auto_monitorTarget="variable_analogue_input_0">
            <font font_id="verdana" font_size="25" colour="255,255,255,255"></font>
            <display location="37,219" page="1"></display>
            <config decimals="2" max_size="355,70"></config>
          </text_label>
          <text_label id="Text_Label_Analogue_Input_1" text="Analogue Input 1: " auto_monitor="variable" auto_monitorTarget="variable_analogue_input_1">
            <display location="412,219" page="1"></display>
          </text_label>
          <text_label id="Text_Label_Analogue_Input_2" text="Analogue Input 2: " auto_monitor="variable" auto_monitorTarget="variable_analogue_input_2">
            <display location="37,319" page="1"></display>
          </text_label>
          <text_label id="Text_Label_Analogue_Input_3" text="Analogue Input 3: " auto_monitor="variable" auto_monitorTarget="variable_analogue_input_3">
            <display location="412,319" page="1"></display>
          </text_label>
          <text_label id="Text_Label_Analogue_Input_4" text="Analogue Input 4: " auto_monitor="variable" auto_monitorTarget="variable_analogue_input_4">
            <display location="37,119" page="2"></display>
          </text_label>
          <text_label id="Text_Label_Analogue_Input_5" text="Analogue Input 5: " auto_monitor="variable" auto_monitorTarget="variable_analogue_input_5">
            <display location="412,119" page="2"></display>
          </text_label>
          <text_label id="Text_Label_Analogue_Input_6" text="Analogue Input 6: " auto_monitor="variable" auto_monitorTarget="variable_analogue_input_6">
            <display location="37,219" page="2"></display>
          </text_label>
          <text_label id="Text_Label_Analogue_Input_7" text="Analogue Input 7: " auto_monitor="variable" auto_monitorTarget="variable_analogue_input_7">
            <display location="412,219" page="2"></display>
          </text_label>
          <text_label id="Text_Label_Analogue_Input_8" text="Analogue Input 8: " auto_monitor="variable" auto_monitorTarget="variable_analogue_input_8">
            <display location="37,319" page="2"></display>
          </text_label>
          <text_label id="Text_Label_Analogue_Input_9" text="Analogue Input 9: " auto_monitor="variable" auto_monitorTarget="variable_analogue_input_9">
            <display location="412,319" page="2"></display>
          </text_label>
      <!-- End Text Labels -->
      </graphics>
      <io>
      <!-- Begin Fusion Brain Instances -->
          <brain id="My Fusion Brain 0">brain id 0</brain>
      <!-- End Fusion Brain Instances -->
      <!-- Begin Timer Setup -->
          <timer id="input" interval="5"></timer>
          <timer id="output" interval="5"></timer>
          <timer id="gui" interval="5"></timer>
          <timer id="logic" interval="5"></timer>
      <!-- End Timer Setup -->
      <!-- Begin Digital Output Instances -->
          <iochannel id="Digital Output 0" port="0" brain="my fusion brain 0" type="digital_output">
            <defaults defaultstate="on"></defaults>
          </iochannel>
          <iochannel id="Digital Output 1" port="1" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="Digital Output 2" port="2" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="Digital Output 3" port="3" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="Digital Output 4" port="4" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="Digital Output 5" port="5" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="Digital Output 6" port="6" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="Digital Output 7" port="7" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="Digital Output 8" port="8" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="Digital Output 9" port="9" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="Digital Output 10" port="10" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="Digital Output 11" port="11" brain="my fusion brain 0" type="digital_output">
          </iochannel>
      <!-- End Digital Output Instances -->
      <!-- Begin Analogue Input Instances -->
          <iochannel id="Analogue Input 0" port="0" brain="my fusion brain 0" type="analogue_input">
            <options history="3" auto_average="false"></options>
          </iochannel>
          <iochannel id="Analogue Input 1" port="1" brain="my fusion brain 0" type="analogue_input">
            <options history="15" auto_average="false"></options>
          </iochannel>
          <iochannel id="Analogue Input 2" port="2" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="Analogue Input 3" port="3" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="Analogue Input 4" port="4" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="Analogue Input 5" port="5" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="Analogue Input 6" port="6" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="Analogue Input 7" port="7" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="Analogue Input 8" port="8" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="Analogue Input 9" port="9" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
      <!-- End Analogue Input Instances -->
      </io>
      <logic>
      <!-- Begin Logging Setup -->
        <all_logging>
        </all_logging>
      <!-- End Logging Setup -->
      <!-- Begin Variable Declarations -->
        <all_variables>
          <variable name="variable_analogue_input_0">0</variable>
          <variable name="variable_analogue_input_1">0</variable>
          <variable name="variable_analogue_input_2">0</variable>
          <variable name="variable_analogue_input_3">0</variable>
          <variable name="variable_analogue_input_4">0</variable>
          <variable name="variable_analogue_input_5">0</variable>
          <variable name="variable_analogue_input_6">0</variable>
          <variable name="variable_analogue_input_7">0</variable>
          <variable name="variable_analogue_input_8">0</variable>
          <variable name="variable_analogue_input_9">0</variable>
        </all_variables>
      <!-- End Variable Declarations -->
      <!-- Begin Logic Declarations -->
        <all_statements>
          <if fire_on="logic" minimum_delta_vote_time="100" id="Logic for Analogue Input 0">
            <variable do="set" name="Variable_Analogue_Input_0">
                <analogue id="Analogue Input 0" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="Logic for Analogue Input 1">
            <variable do="set" name="Variable_Analogue_Input_1">
                <analogue id="Analogue Input 1" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="Logic for Analogue Input 2">
            <variable do="set" name="Variable_Analogue_Input_2">
                <analogue id="Analogue Input 2" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="Logic for Analogue Input 3">
            <variable do="set" name="Variable_Analogue_Input_3">
                <analogue id="Analogue Input 3" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="Logic for Analogue Input 4">
            <variable do="set" name="Variable_Analogue_Input_4">
                <analogue id="Analogue Input 4" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="Logic for Analogue Input 5">
            <variable do="set" name="Variable_Analogue_Input_5">
                <analogue id="Analogue Input 5" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="Logic for Analogue Input 6">
            <variable do="set" name="Variable_Analogue_Input_6">
                <analogue id="Analogue Input 6" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="Logic for Analogue Input 7">
            <variable do="set" name="Variable_Analogue_Input_7">
                <analogue id="Analogue Input 7" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="Logic for Analogue Input 8">
            <variable do="set" name="Variable_Analogue_Input_8">
                <analogue id="Analogue Input 8" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="Logic for Analogue Input 9">
            <variable do="set" name="Variable_Analogue_Input_9">
                <analogue id="Analogue Input 9" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="Root Function #2">
            <boolean_operation type="between ii">
              <parameter1>
                <number>1</number>
              </parameter1>
              <parameter2>
              </parameter2>
              <parameter3>
                <number>5</number>
              </parameter3>
            </boolean_operation>
            <then>
              <do function="Send Key To Foreground" functionTargetID="Required Filler" vote_opinion="A" vote_priority="Low"></do>
            </then>
          </if>
        </all_statements>
      <!-- End Logic Declarations -->
      </logic>
    </FusionControlCentreConfiguration>
    Save the file in Notepad.
    Open the "Fusion Control Centre UberMDX.exe", located in the same directory as you just were.
    You will be greeted with a skin that does the following:
    1.) allows control of all 12 digital outputs
    2.) displays the current status of all 10 analog inputs
    3.) sends the key "a" to the foreground whenever analog input 0 is between 1 and 5 volts.
    So run this, apply a voltage to analog input 0, and open a notepad window - it'll start filling up with "a"s.
    again, FOLLOW THE ABOVE STEPS CAREFULLY.
  10. #120
    Oct 2005
    Quote Originally Posted by greenman100 View Post
    honesty, and i want you to think carefully before you answer this, did you do exactly what 2k1 posted in his video? We're getting frustrated here - your messages are vague and conflicting. Several dozens of users have managed to do what you are trying to do, with nothing but what we've provided so far. In a last ditch attempt to help, please follow these steps carefully.
    Navigate to: C:\program files\fusion control centre uber mdx edition\mdx
    right click "fusionconfiguration.xml"
    select edit from the menu.
    Code:
    <fusioncontrolcentreconfiguration version="3.0" author="ninja kitty wizard of doom" date_created="wednesday, october 01, 2008 at 10:04:18 pm" last_modified="wednesday, november 12, 2008 at 5:41:34 pm">
      <require>
      <!-- begin function instances -->
      <!-- end function instances -->
      <!-- begin fusion font instances -->
          <font name="verdana" originalsize="25" font_config="content\fonts\verdana.xml"></font>
      <!-- end fusion font instances -->
      </require>
      <!-- begin system speech instances -->
      <!-- end system speech instances -->
      <!-- begin system speech definition instances -->
      <!-- end system speech definition instances -->
      <!-- begin custom speech definition instances -->
      <!-- end custom speech definition instances -->
      <!-- begin custom query instances -->
          <custom_queries>
          </custom_queries>
      <!-- end custom query instances -->
      </speech>
      <general>
      <!-- begin debug instances -->
        <debug status="on">
        </debug>
      <!-- end debug instances -->
      <!-- begin remote control configuration -->
      <!-- end remote control configuration -->
      </general>
      <graphics>
      <!-- begin global graphic settings -->
          <main_display designed_for_size="800,600" show_at_size="800,600" menubar="sizeable" runinsystemtray="false" minimizetosystemtray="true"></main_display>
      <!-- end global graphic settings -->
      <!-- begin background images -->
      <!-- end background images -->
      <!-- begin static images -->
          <staticimage>
          </staticimage>
          <staticimage>
          </staticimage>
          <staticimage>
          </staticimage>
          <staticimage>
          </staticimage>
          <staticimage>
          </staticimage>
          <staticimage>
          </staticimage>
          <staticimage>
          </staticimage>
          <staticimage>
          </staticimage>
          <staticimage>
          </staticimage>
          <staticimage>
          </staticimage>
          <staticimage>
          </staticimage>
      <!-- end static images -->
      <!-- begin variable location images -->
      <!-- end variable location images -->
      <!-- begin graph instances -->
      <!-- end graph instances -->
      <!-- begin display buttons -->
          <button id="ninjabutton_digital_output_0" enabled="yes" function="trigger output" functiontargetid="digital output 0" vote="attached" vote_opinion="on" vote_priority="medium">
            <images imageprimary="content\images\button_images\button_down.png" imagesecondary="content\images\button_images\button.png" imagedisabled="content\images\button_images\button.png" imagepushed="content\images\button_images\button_down.png"></images>
            <text colourprimaryargb="255,255,255,255" textprimary="digital output 0"></text>
            <text coloursecondaryargb="255,255,255,255" textsecondary="digital output 0"></text>
          </button>
          <button id="ninjabutton_digital_output_1" enabled="yes" function="trigger output" functiontargetid="digital output 1" vote="attached" vote_opinion="on" vote_priority="medium">
            <text colourprimaryargb="255,255,255,255" textprimary="digital output 1"></text>
            <text coloursecondaryargb="255,255,255,255" textsecondary="digital output 1"></text>
          </button>
          <button id="ninjabutton_digital_output_2" enabled="yes" function="trigger output" functiontargetid="digital output 2" vote="attached" vote_opinion="on" vote_priority="medium">
            <text colourprimaryargb="255,255,255,255" textprimary="digital output 2"></text>
            <text coloursecondaryargb="255,255,255,255" textsecondary="digital output 2"></text>
          </button>
          <button id="ninjabutton_digital_output_3" enabled="yes" function="trigger output" functiontargetid="digital output 3" vote="attached" vote_opinion="on" vote_priority="medium">
            <text colourprimaryargb="255,255,255,255" textprimary="digital output 3"></text>
            <text coloursecondaryargb="255,255,255,255" textsecondary="digital output 3"></text>
          </button>
          <button id="ninjabutton_digital_output_4" enabled="yes" function="trigger output" functiontargetid="digital output 4" vote="attached" vote_opinion="on" vote_priority="medium">
            <text colourprimaryargb="255,255,255,255" textprimary="digital output 4"></text>
            <text coloursecondaryargb="255,255,255,255" textsecondary="digital output 4"></text>
          </button>
          <button id="ninjabutton_digital_output_5" enabled="yes" function="trigger output" functiontargetid="digital output 5" vote="attached" vote_opinion="on" vote_priority="medium">
            <text colourprimaryargb="255,255,255,255" textprimary="digital output 5"></text>
            <text coloursecondaryargb="255,255,255,255" textsecondary="digital output 5"></text>
          </button>
          <button id="ninjabutton_digital_output_6" enabled="yes" function="trigger output" functiontargetid="digital output 6" vote="attached" vote_opinion="on" vote_priority="medium">
            <text colourprimaryargb="255,255,255,255" textprimary="digital output 6"></text>
            <text coloursecondaryargb="255,255,255,255" textsecondary="digital output 6"></text>
          </button>
          <button id="ninjabutton_digital_output_7" enabled="yes" function="trigger output" functiontargetid="digital output 7" vote="attached" vote_opinion="on" vote_priority="medium">
            <text colourprimaryargb="255,255,255,255" textprimary="digital output 7"></text>
            <text coloursecondaryargb="255,255,255,255" textsecondary="digital output 7"></text>
          </button>
          <button id="ninjabutton_digital_output_8" enabled="yes" function="trigger output" functiontargetid="digital output 8" vote="attached" vote_opinion="on" vote_priority="medium">
            <text colourprimaryargb="255,255,255,255" textprimary="digital output 8"></text>
            <text coloursecondaryargb="255,255,255,255" textsecondary="digital output 8"></text>
          </button>
          <button id="ninjabutton_digital_output_9" enabled="yes" function="trigger output" functiontargetid="digital output 9" vote="attached" vote_opinion="on" vote_priority="medium">
            <text colourprimaryargb="255,255,255,255" textprimary="digital output 9"></text>
            <text coloursecondaryargb="255,255,255,255" textsecondary="digital output 9"></text>
          </button>
          <button id="ninjabutton_digital_output_10" enabled="yes" function="trigger output" functiontargetid="digital output 10" vote="attached" vote_opinion="on" vote_priority="medium">
            <text colourprimaryargb="255,255,255,255" textprimary="digital output 10"></text>
            <text coloursecondaryargb="255,255,255,255" textsecondary="digital output 10"></text>
          </button>
          <button id="ninjabutton_digital_output_11" enabled="yes" function="trigger output" functiontargetid="digital output 11" vote="attached" vote_opinion="on" vote_priority="medium">
            <text colourprimaryargb="255,255,255,255" textprimary="digital output 11"></text>
            <text coloursecondaryargb="255,255,255,255" textsecondary="digital output 11"></text>
          </button>
          <button id="button_changepage_next" enabled="yes" function="change page" functiontargetid="required filler" vote="attached" vote_opinion="+1" vote_priority="medium">
            <images imageprimary="content\images\button_images\button_next.png" imagesecondary="content\images\button_images\button_next.png" imagedisabled="content\images\button_images\button_next.png" imagepushed="content\images\button_images\button_next_down.png"></images>
          </button>
          <button id="button_changepage_previous" enabled="yes" function="change page" functiontargetid="required filler" vote="attached" vote_opinion="-1" vote_priority="medium">
            <images imageprimary="content\images\button_images\button_previous.png" imagesecondary="content\images\button_images\button_previous.png" imagedisabled="content\images\button_images\button_previous.png" imagepushed="content\images\button_images\button_previous_down.png"></images>
          </button>
      <!-- end display buttons -->
      <!-- begin multi images -->
      <!-- end multi images -->
      <!-- begin text labels -->
          <text_label id="text_label_analogue_input_0" text="analogue input 0: " auto_monitor="variable" auto_monitortarget="variable_analogue_input_0">
          </text_label>
          <text_label id="text_label_analogue_input_1" text="analogue input 1: " auto_monitor="variable" auto_monitortarget="variable_analogue_input_1">
          </text_label>
          <text_label id="text_label_analogue_input_2" text="analogue input 2: " auto_monitor="variable" auto_monitortarget="variable_analogue_input_2">
          </text_label>
          <text_label id="text_label_analogue_input_3" text="analogue input 3: " auto_monitor="variable" auto_monitortarget="variable_analogue_input_3">
          </text_label>
          <text_label id="text_label_analogue_input_4" text="analogue input 4: " auto_monitor="variable" auto_monitortarget="variable_analogue_input_4">
          </text_label>
          <text_label id="text_label_analogue_input_5" text="analogue input 5: " auto_monitor="variable" auto_monitortarget="variable_analogue_input_5">
          </text_label>
          <text_label id="text_label_analogue_input_6" text="analogue input 6: " auto_monitor="variable" auto_monitortarget="variable_analogue_input_6">
          </text_label>
          <text_label id="text_label_analogue_input_7" text="analogue input 7: " auto_monitor="variable" auto_monitortarget="variable_analogue_input_7">
          </text_label>
          <text_label id="text_label_analogue_input_8" text="analogue input 8: " auto_monitor="variable" auto_monitortarget="variable_analogue_input_8">
          </text_label>
          <text_label id="text_label_analogue_input_9" text="analogue input 9: " auto_monitor="variable" auto_monitortarget="variable_analogue_input_9">
          </text_label>
      <!-- end text labels -->
      </graphics>
      <io>
      <!-- begin fusion brain instances -->
          <brain id="my fusion brain 0">brain id 0</brain>
      <!-- end fusion brain instances -->
      <!-- begin timer setup -->
      <!-- end timer setup -->
      <!-- begin digital output instances -->
          <iochannel id="digital output 0" port="0" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="digital output 1" port="1" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="digital output 2" port="2" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="digital output 3" port="3" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="digital output 4" port="4" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="digital output 5" port="5" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="digital output 6" port="6" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="digital output 7" port="7" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="digital output 8" port="8" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="digital output 9" port="9" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="digital output 10" port="10" brain="my fusion brain 0" type="digital_output">
          </iochannel>
          <iochannel id="digital output 11" port="11" brain="my fusion brain 0" type="digital_output">
          </iochannel>
      <!-- end digital output instances -->
      <!-- begin analogue input instances -->
          <iochannel id="analogue input 0" port="0" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="analogue input 1" port="1" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="analogue input 2" port="2" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="analogue input 3" port="3" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="analogue input 4" port="4" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="analogue input 5" port="5" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="analogue input 6" port="6" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="analogue input 7" port="7" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="analogue input 8" port="8" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
          <iochannel id="analogue input 9" port="9" brain="my fusion brain 0" type="analogue_input">
          </iochannel>
      <!-- end analogue input instances -->
      </io>
      <logic>
      <!-- begin logging setup -->
        <all_logging>
        </all_logging>
      <!-- end logging setup -->
      <!-- begin variable declarations -->
        <all_variables>
        </all_variables>
      <!-- end variable declarations -->
      <!-- begin logic declarations -->
        <all_statements>
          <if fire_on="logic" minimum_delta_vote_time="100" id="logic for analogue input 0">
            <variable do="set" name="variable_analogue_input_0">
                <analogue id="analogue input 0" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="logic for analogue input 1">
            <variable do="set" name="variable_analogue_input_1">
                <analogue id="analogue input 1" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="logic for analogue input 2">
            <variable do="set" name="variable_analogue_input_2">
                <analogue id="analogue input 2" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="logic for analogue input 3">
            <variable do="set" name="variable_analogue_input_3">
                <analogue id="analogue input 3" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="logic for analogue input 4">
            <variable do="set" name="variable_analogue_input_4">
                <analogue id="analogue input 4" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="logic for analogue input 5">
            <variable do="set" name="variable_analogue_input_5">
                <analogue id="analogue input 5" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="logic for analogue input 6">
            <variable do="set" name="variable_analogue_input_6">
                <analogue id="analogue input 6" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="logic for analogue input 7">
            <variable do="set" name="variable_analogue_input_7">
                <analogue id="analogue input 7" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="logic for analogue input 8">
            <variable do="set" name="variable_analogue_input_8">
                <analogue id="analogue input 8" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="logic for analogue input 9">
            <variable do="set" name="variable_analogue_input_9">
                <analogue id="analogue input 9" time="0"></analogue>
            </variable>
          </if>
          <if fire_on="logic" minimum_delta_vote_time="100" id="root function #2">
              <parameter1>
                <number>1</number>
              </parameter1>
              <parameter2>
              </parameter2>
              <parameter3>
                <number>5</number>
              </parameter3>
            <then>
              <do function="send key to foreground" functiontargetid="required filler" vote_opinion="a" vote_priority="low"></do>
            </then>
          </if>
        </all_statements>
      <!-- end logic declarations -->
      </logic>
    </fusioncontrolcentreconfiguration>
    save the file in notepad.
    Open the "fusion control centre ubermdx.exe", located in the same directory as you just were.
    Again, follow the above steps carefully.
    i did every thing he did in the video
  1. Toyota Steering Wheel Control Question
    By 205GTi in forum Input Devices
    Last Post: 05-21-2014, 10:57 PM
  2. Steering Wheel ADD-ON Controls w/o System
    By ChaCha in forum General Hardware Discussion
    Last Post: 11-16-2012, 02:19 PM
  3. Replies: 2
    Last Post: 05-23-2006, 12:56 PM
  4. RF keyfob remotes for adhoc steering wheel controls?
    By archimense in forum Input Devices
    Last Post: 12-23-2004, 05:27 AM
